0x80070571 Unreadable / corrupt file error message comes up lately when ever i try to move or edit a folder on my Maxtor external Hard Drive. After several attempts to do a disc check, it finally accepts my prompt for a check, takes like 5 hrs to complete it, then says my drive is repaired and ok. Within 2 hrs, all of a sudden i get the same error message again about corrupt files. Somehow i believe it's not a coincidence that my computer did a microsoft automatic update, and since then it hasnt been right. Please help. I got 350 gigs of music on there and i lose folders everytime this happens
  • 19 more comments
  • elsa99 Aug 19, 2008
    My Maxtor storage device is giving me an error code 0x80070571. It says it's corrupted and won't save my files.
    How can I fix this?
  • hanjo7 Oct 04, 2008
    i get the same message whenever i try to move file to or even making a new folder to the maxtor one touch 4 plus (1tb) then window pops a message. "Error 0x80070571: The disk structure is corrupted and unreadable." please some one help us fix this problem.
  • Anonymous Oct 06, 2008
    I have the same external disk, a Maxtor 1 Tb one Touch 4 plus, and have the same problem. I use Vista Ultimate 64 bit which give's rise to a seperate problem when trying to use a firewire connection rather than usb
  • bblover253 Oct 09, 2008
    I am trying to burn Ubundu onto a disk and the SAME things just keeps popping up! HELP
  • Anonymous Oct 12, 2008
    Have exactly the same issue. Any ideas how to fix it?
  • Anonymous Oct 20, 2008
    I have the same problem. I am trying to delete a file off my Maxtor One Touch 4 external hard drive and get the same error message. Help?
  • bt1100 Nov 23, 2008
    hi guys,
    thats correctly my Problem on thet same drive.. two artitions a ~250gb the "z",the second partition on that drive tells me temporaly this error if i delete an file,Folder ore whatelse. the only way to fix i found up until now is, to defrag after an reboot.
    any one other fixes? is my maxtor on the way to "nirwana" ?? ;)
    thx for ideas
  • WelshMatty Dec 04, 2008
    Yes, I've just purchased a new PC because my old one bit the dust...I can't copy to the drive, but I can copy files from it. I last accessed the drive about a month ago. All these posts seem fairly recent, perhaps its an update issue.
  • tracey913 Dec 08, 2008
    Same problem on new HP Compaq-after using it for a bit, I get the "disk structure is corrupted and unreadable" message. I reboot to run chkdsk and it is fine for a bit-then suddenly the message pops up again. Different apps everytime to.
  • Anonymous Dec 21, 2008
    Same problem on Western Digital WDH2Q20000.
  • Anonymous Feb 20, 2009
    same problem on seagate 500gb external harf
  • Anonymous Feb 22, 2009
    i can send files to the hard drive!
  • Anonymous Mar 03, 2009
    When I try to copy a folder or file to my external hard drive I get the same error:
    error:0x80070571 The disc structure is corrupted and unreadable
  • Pauline Mar 03, 2009
    Same problem when I'm trying to copy files/folders to my external storage drive:
    error: 0x80070571 The disc structure is corrupted and unreadable.
  • tmj76 Mar 11, 2009
    I have a Maxtor 320GB external hard drive and everytime I try to delete a file or folder I recieve an error code (0x80070571).
  • Anonymous Mar 16, 2009
    Mine is doing the exact same thing, i really hope it can be helped I will be devasted if it is all wiped...
  • Kimusahvi Apr 25, 2009
    Every time i try to delete something it pops up and says this. -.-
    GRRR IT POPS UP AND SAYS THIS EACH TIME I TRY TO DOWNLOAD THAT TO FIX IT!!!!!
  • k_ladthamon
    k_ladthamon Nov 13, 2012
    i have the same problem, i try to create new folder and copy something from that drive but i get an error code 0x80070571: the disk structure is corrupted and unreadable; some one can solve my problem? please help me!!
  • midnightcowboy Sep 27, 2013
    Simply Disable your Antivirus "Access Protection"
    Novelist:
  • 113 Answers
This is a program provided by seagate for to check your hdd. This program has other options and has a friendly user interface that may help you find a solution to your problem.
simply install and run this tool and your drive will be properly repaired, as this error code is typicall for data corruption.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=seatools-win&vgnextoid=552bd20cacdec010VgnVCM100000dd04090aRCRD
Take the time to run the complete test.....Good Luck!!
Posted on Mar 11, 2009
I experienced a similar problem. Although I had no limits set I continually got this message when attempting to add additional music fies to my folder. After some time I realized that the problem occurred because I was exceeding 130
G byte in that folder.splitting the folder in half ie Music 1 and Music 2 solved the problem.
Posted on May 17, 2009
Problem Solved!!
Posted on Nov 08, 2012
  • mjvfertwo03
    mjvfertwo03 Nov 08, 2012
    Problem Solved!!
    yes you are right thanks a lot
Error 0x80070571
your data that you are sending to the hard drive might be corrupt or the hard drive isn't spinning at the correct rpm.
Apr 08, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
I can not copy or remove files tot mine extern harddisk Maxtor and the error shows 0x80070571. What can i do? How to repair I have already done cksdsk but is does not help
There are several things that come up for this error message.
1. The files you are trying to copy over to your external maybe corrupt. (What type of files are you trying to copy, windows files or just personal data ?)
2. Your External HDD is either damaged, or not hooked up correctly. Make sure all cables etc are secure and working, try a different set of cables if possible.
3. You can try this tool that will analyze your hard drive for problems. CLICK HERE.
Post back if you have any questions or comments.
Mar 21, 2011 | Computers & Internet
Maxtor 1TB external HDD says files are corrupt
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 02, 2010 | Maxtor Hard Drive
Error code 0X80070571 with the external HDD
The Seatools test has verified that the "physical" hardware is working fine, which is good news.
However, the error-message "disk structure is corrupted" means that there is a "logical" problem. Compare it to a book with a Table of Contents that has been overwritten by a two-year-old with crayons;
the pages are not physically torn nor missing, but you cannot "read" the original Table of Contents information.
Connect the drive, and note which drive-letter that Windows assigns, e.g., 'E:'.
Click Start
Click Run
Type CMD and press ENTER
Type CHKDSK E: /F and press ENTER,
and let Windows try to reconstruct the Table of Contents on the disk.
Jan 02, 2010 | Maxtor Personal Storage 3200 (M1227310)...
Mator 500 gig (one touch) 4 external hard drive & error 80070571
have you tried formating the h/d it will solve the error msg
Mar 16, 2009 | Maxtor Hard Drive
Maxtor 3200 error message
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If it doesn't make any unusual sounds and doesn't show up in BIOS - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.  if it is recognized with full capacity and only files are unreadable - try to scan it with demo version of some software like R-Studio or GetDataBack.
Dec 30, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Hi, I lost user manual, need to restore files back to computer.
Provided that you can find your external drive using My Computer feature, double click on that drive icon and search the drive for the files you wish to put on the computer drive (C drive). If you right click the file or folder on the Maxtor external drive and then choose copy, you can go to the folder on the C drive that you want to paste them into, select it and then right click the folder icon and choose paste to put them into the folder. To make the process quicker, you might choose to paste all files and/or files from the Maxtor drive onto the computer desktop and then move them around later.
Dec 27, 2008 | Maxtor OneTouch III Mini Edition 120GB...
About my seagate 160 gb hard drive (external)
i hav usb seagate 160 gb hard disk.nw it is nt getting open message is the file or directory is corrupted or unreadable........CHKDSK is also not working for it.error is "unable to determine volume version and start"....plz help fast
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Computers & Internet Logo
17,042 people viewed this question
David Payne
David Payne
