Question about Goodmans W280NS Television
No picture Hi please help the tv powers up and all menus come up but no picture of tv can you help?
  • Anonymous Aug 02, 2008
    I have exactly the same problem, although sometimes the screen just fuzzy's black instead of a still black/blue image. Works fine on VGA though.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Change your mainboard
Posted on Oct 11, 2008
What to change in this LG 50PZ650? TV powers on, but there is no picture at all, can someone shed some lights on the different components in the picture and what to replace Thank you in advance.
Hi , first, is the antenna attached and fully functioning? Attaching another device to it will show if this is the source of your issue.
If the aerial is okay and you can access the tv menus ensure the source is set to digital .
Then go into the menus available from the remote and find the option to reset to factory default. If your problem is not a hardware fault this should remedy it.
If after hard resetting the set still does not work the issue will probably be with the power control card or the mainboard.
video for the power control card repair here
https://www.youtube.com/watch?v=0Z_T_cS_B7g
The fault may clear if it does not you may want to consult a technician about diagnosing for you
Jun 12, 2015 | LG Televison & Video
My samsung tv model UN29F4000, has sound but no picture, no menus come up. I'm not sure if it has a tconn board or not. What is the most common problem with a tv with these symptoms
The most of this TV problem is that the inverter transformer built on the main power supply is bad, to fix it, you may replace the transformer , or replace the power supply module.
Apr 06, 2015 | Samsung Televison & Video
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
Aug 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Digital Lifstyles 42
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
GOOD LUCK....
May 21, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Model 542-B11 External signal won't display (settings menus work)
Well first of all yo can try to reset your TV, just turn it off for more the 24 hours and then turn it on again, it helps you to reset your TV. (turn off your TV from main housing not only from the TV power button).
Let us know if this helps....
Good Luck!!
Thanks
Dec 14, 2009 | Televison & Video
My new samsung ps42a457 plasma tv wont keep its modified settings
hi hold down exit botton until menu appears,it is set in shop demo please select home use and follow instructions that will sort it
Mar 26, 2009 | Samsung PN42A450 Plasma TV
No Picture At All on my DLP Mitsubishi
First do a self test to get error codes. To do this look on threads here or go to ctechnicians.com
Dec 31, 2007 | Mitsubishi WD-52628 52" Projection HDTV
Picture shifted and ghost image
Try using an input other than the tuner. I.e a DVD player or game system on the front inputs. If the picture looks OK on the other input, your tuner is damaged and will need replaced, if it looks bad also, try unplugging the TV for 5 minutes and then go through the setup process in the menus. If this fails seek a repair shop.
Sep 08, 2007 | Toshiba 34HF81 34" TV
Blank pic
More info please, how old is the set? How much do you know about tvs? Do you have menus on screen? Do you have Raster?
Jul 02, 2007 | Toshiba 42H82 42" Rear Projection...
RCA tv only in black and white?
The route through the circuits in the TV from the various sources all lead to the final video amplifiers for red green and blue. Somewhere along the route is a circuit called a colour switch. This allows colour if the signal is strong enough, otherwise it only allows black and white. This fault suggests a weak video chip which is the one just before the switch circuit. the fault could also be a faulty coupling capacitor to or from this chip, or a low power supply voltage. Check for dry soldered joints around this circiut. Please note if resoldering on new televisions that they may have non leaded solder which requires about 50 degrees centigrade hotter iron.
Oct 15, 2006 | RCA F27628 27" TV
Televison & Video Logo
35 people viewed this question
Top Goodmans Televison & Video Experts
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
