Compaq c300 It works fine if you put a fresh battery in it but it will not run or turn on using the ac adapter. It is a universal adapter not the origional equipment. The lites flash but nothing else will happen. The last time it shut down it said it was going to hibernate. I cannot wake it up. I have ordered the origional adapter to see if that helps. I understand it was not used for a long period of time. Now will not run on ac power or charge the battery. The battery is 10.8v and the charger is like 18.5, Is that correct?
  • Dave Dufresne Feb 15, 2009
    fresh battery solves it all but when that power sorce is used up shuts down so i see it as the voltage regulator(vrm) but where is it on my compaq c300.... what ive found is all lights work right w/fresh battery but when that is used up lights flash on front panel the computer isnt charging the battery at all the comp[uter wont turn on with just a ac/dc input soooo help me find my voltage regulator please
    Problem Solver:
  • 12 Answers
Some times the power jack might be defective . You will need to replace it or you can take it to a service center
You can check this web site for the jack
http://powerjack.us/index.php?main_page=product_info&products_id=10042&zenid=ca1ef873d4514f0fcc442d64bbd4c734
Thank You
thewho1
Posted on Aug 01, 2008
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
I have a HP/Compaq 6510b laptop computer and it will not turn on...I have the charger plugged in and the only thing happening is the green light periodically flashes...Is the battery bad?
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Feb 17, 2011 | HP Original HP COMPAQ 6510b 6515b 6710b AC...
Advent k200 laptop does not charge new battery
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Computers & Internet
Advent k 200 laptop does not charge battery
Does not charge
hi,
you can try to conect the laptop directly to the power outlet without using the battery just to verify if it the battery or the charger itself..If it still power up the laptop,that means that the adapter is still working,if not,well obviously,its the battery itself
thanks
Jul 06, 2010 | ASUS AC Adapter- Universal Notebook AC...
Green light is on on the adapter, but doesnt charge battery
1. the adapter may be ok but the unit battery that the adapter is charging may have a bad cell and not taking the charge or the power connector may need replacement .
Only a qualified tech can determine this by doing electrical checks with a meter and or diagnostic instrument.
Take your unit to a tech to do a diagnostic.
More than likely it is the battery.
Jan 29, 2010 | ASUS AC Adapter- Universal Notebook AC...
Hi there, When plugged in nothing happens. What could it be?
Only a few things come to mind:
1. The plug on the MB is defective
Solution: Have the plug on the motherboard replaced
2. The universal power adapter is defective
Solution: Buy an ASUS power adapter and test it out. If it doesn't work, return it. If it does, then get rid of the universal adapter.
Good luck
-Carlos:
Jan 07, 2010 | ASUS AC Adapter- Universal Notebook AC...
Asus ac adapter will not wrk green light on adapter
First check the wall socket make sure you are getting power, plug a lamp into it for instance. If there is no green light on the adapter then it is bad and you will need to order a new one from your computer manufactor.
rate with 4 diamonds
Mar 02, 2009 | ASUS AC Adapter- Universal Notebook AC...
Ac power adapter
Both at Walmart and Radio Shack you can find universal adapters that allow you to change the connector and voltage to fit the device. Try one of these, you can usually pick one up for under $10.
Nov 26, 2007 | Computers & Internet
Computers & Internet Logo
137 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
