Question about Mitsubishi VS-70707 70" Rear Projection Television
Mitsubishi vs-7071 rear projection tv
I've had this tv for over 9 years and have never had a problem with it till the other night. The tv started to have a horizontal roll in the image. We turned the TV off and and when we turned it back on the image was very dark and continued to roll. If left on for about a half hour the image will stop rolling until you hit the menu button then it starts to scroll again. If you turn it off and let it cool off you can repeat this over and over again.
When the image does stop scrolling the bottom half of the screen is a pale green color but can be adjusted out if you reduce the color menu to half way.
any help would be appreciated!
  • Banshee4 Dec 12, 2008
    i have the same tv with the same problem.
  • rebecka_may0 Dec 26, 2008
    color distortion and lines across the screen.
Hey i have had the same prob on my other tv .it was about 300 to get it fixed.if you havent allready fixed it and if your not to fare away,id like to buy the screen
Posted on Sep 13, 2008
I had a similar problem years ago. A fellow replaced the PIP module, and it worked like new. PIP module cost me $100 with exchange.
Posted on Mar 14, 2010
  • 927 Answers
Good Day, firefighter1;
IT SOUNDS YOU HAVE A PROBLEM IN THE 9 VOLT CIRCUIT: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB. THAT SHOULD SOLVE YOUR PROBLEM, IT'S COMMON FOR THIS TV.
GOOD LUCK, big IRISH>
Posted on Aug 01, 2008
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi has a problem
Ur Horizontal/Vertical ic stablizer is dead or it supporting componnents.90% is ur IC.
Aug 25, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Screen is blue
the problem will either fix itself out or the screen will go. chances are one color goes then the next and then its toast but can go after blue as well.
Aug 06, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Jul 30, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Picture problems
We called a tv repair guy. It wasnt anything we could have fixed easily. Thank though.
Mar 31, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-70707 70" Rear Projection Television Logo
841 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
