Question about Garmin GPS
N95 garmin dose not use the built in gps but looks for device
Hi, this happens because your garmin is locked.
check the following post for details:
http://www.ipmart-forum.com/showthread.php?t=240101
Posted on Jul 31, 2008
Garmin 2555LMT car charger doesn't have transmitter in middle of cord. Is it at the base of the car charger?
The block taht was in the power line of older GPS devices was for traffic only, NOT gps siginal. modern Garmin units have the traffic portion built into the Case of the head unit. GPS reciever is ALWAYS in the case of the head unit.
Jul 16, 2014 | Garmin Nuvi 2555Lmt Gps Receiver
Is my nuvi255w bluetooth ready?
The Garmin Nuvi 255 GPS does have Bluetooth built in.
Here is a link to the product specs at the Garmin site.
https://buy.garmin.com/shop/shop.do?cID=134&pID=13428
May 13, 2011 | Garmin GPS
Hello there, I bought a china brand gps with built in garmin mobile xt, how do install road maps. I'm from the philippines by the way.. Thanks for helping me...
Welcome to FixYa!
To update your map, go to https://my.garmin.com/maps/chooseDeviceType.htm? Choose your device type. I believe Garmin Mobile XT is under the "Phone Devices".
It will ask you to install the Garmin Communicator Plugin, install it and follow the instructions. You may need to connect your GPS to the computer during this process.
I'm not quite sure if a road map for Philippines is available though.
Thank you for using FixYa. Have a great day. Jas247
Note: CDRKing also released a less expensive GPS tailored for Philippines.
May 13, 2011 | Garmin Mobile XT GPS Receiver
I have a Garmin 178 with built in antenna. having
I dont thoink a bigger antenna is the solution because i'm having the same problem with my 178c and the built in antenna has always worked fine before.
Jul 01, 2010 | Garmin nuvi 200W GPS Receiver
Wont calculat route
sat nav needs a valid gps signal to start calculating route, even if it found entered address. Address is searched on built-in map, not live gps position. That means, sat nav may have problem with gps signal. Try to reset device to its factory settings first. hope this helps
Nov 01, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin went totlly blank during use.is there a
most Garmin's are powered by external sources which charge the device. the device has a battery internally and is kept charged by such a cable connected to the cigarette lighter socket.
If its a built in Garman then most likely its the fuse.
AndystUK
Aug 30, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 260w
Try setting your GPS mode to WAAS and then back. It's a calibration issue. Also, make sure you update your unit.
Jul 16, 2008 | Garmin nuvi 200W GPS Receiver
Connection problem between a nokia n95 8gb and zumo 550
I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
1) Assuming the N95 and Zumo are paired via BlueTooth
2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
4) Select the Zumo 550 device from the list of paired Bluetooth devices
5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
Feb 15, 2008 | Garmin zumo 550 GPS Receiver
SC card
I am not able to look at the map, as it always direct me back to my home. How can I solve the problem ?
Mar 21, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
59 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
