Question about Dell Latitude D600 Notebook
Power problem with dell latitude.
I have a power problem: both my battery and AC adopter are new, but I noticed that my battery is not changin up at all. One time, I let the laptop plugged in for over five hours. Then, I switched into bettery use, but whithin five minutes the battery became dead. So, I removed the battery in order to use the adopter, but the system won't start at all. In addition to that, I checked the battery by pushing the test putton on the battery, and all I could see is one green led. the rest are off. Now, I can't use by laptop due to this problem. Also, at the starting time the Bios showed F1 to continue! before the system died again, because the battery was not fully change.
    Genius:
  • 2,028 Answers
This is a failed power management system on the motherboard. The power management system regulates the power input, usage, allows the machine to switch from AC t battery, and controls the charging. When this fails it can cause problems ranging from battery not charging, power on battery only, power on AC or battery but not both, no power at all, and more. You will most likely have to replace the motherboard, however, there are a few places that do circuitry and component repairs on motherboards. Google motherboard repair facilities, get an estimate, and compare the price to a new board.
Posted on Jul 31, 2008
I have a Dell E6400. I know, ancient! Is it normal that it gets slower when charging? Like when it's using battery power, it's noticeably faster, but when I plug the charger in it just gets slower..
1.Install the system again. If it works, over!
2.remove the battery, and turn on your notebook with charger. If it works, there may be
something wrong with your battery. You can change a new battery.
3.Install the battery,and plug the charger, power your notebook. Open the Power
management, change the Power plan to High performance.
4400mAh 6 cells Dell Latitude E6400 XFR Battery Replacement Notebook... 90W Dell Latitude E6400 Charger Power Cord Replacement AC Adapter Latitude...
Jan 12, 2017 | Dell Computers & Internet
My dell latitude d610 ac power is work is properly but battrey is not charging plz tell me soulition.
If the D610 works when attached to the AC Power Cord, it is likely that your battery is not capable of taking a charge and needs to be replaced. I have 2 D610 Dell Latitudes and they are very good laptops.
Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
Jun 26, 2011 | Dell Latitude D610 Notebook
Dell Latitude D810. I bought a new powr supply from dell. I keep getting a popup saying that it cannot determine the AC power adapter. Also, my battery is dead.
You will get this error when you get a newer power supply than what was originally design for the Latitude, also when the unit came from a 3rd party supplier not on Dell's OEM supplier list, and your battery will some what solve this upon getting a new one.
As for the pop up itself, no harm. Just a nusance. You should be able to turn this off in the Administrator file and select services. Look for power management and deselect monitor AC power.
Good Luck.
C2Solutions
Jan 24, 2011 | Dell POWER SUPPLY Power Supply
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
Dell latitude 100l does not power up
Motherboard may be fried. Try running without the battery installed and on AC, and with battery and NO AC.
Jun 14, 2010 | Dell Latitude 100L Notebook
I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Dec 24, 2009 | Dell Latitude D510 Notebook
Wont operate on battery
Hello bzbeeus,
I'm afraid to tell you that you will need a new ac adaptor. Your ferritt chewing threw your cord did not blow any kind of fuse (besides the fact that there isn't one).
Basically you can search on amazon.com they always have great deals and price comparisons on things of this nature.
Hope this helps steer you in the right direction, thank you for choosing Fixya!
Jul 18, 2009 | Dell Latitude D600 Notebook
No power to dell latitude d600
have you checked your ram? remove it and see if it powers on and qickly turn off. if it powers on replace ram after shutdown. if problem not fixed coud be cpu problem or mobo.
Jun 02, 2009 | Dell Latitude D600 Notebook
Dell latitude D 610 battery dead
dell latitude batteries have a built-in battery life indicator on it. Press the button to see how much charge is left or if there's no charge at all. It sounds like your power adapter isn't charging
your battery. visit: http://accessories.us.dell.com/sna/batteryconfig.aspx?c=us&cs=19&l=en&manufact=694&s=dhs&stype=4&family=Latitude%20Laptops and choose the model of your latitude laptop.
u can get it cheaper on ebay or any 3rd party vendor. hope this helps.
Jun 16, 2008 | Dell Computers & Internet
Dell 620 Battery Issues
Chances are pretty good that your battery just needs to be replaced. Over time all rechargeable batteries loose their ability to hold a charge. It's also possible, but less likely, that there could be an issue with your AC power adapter or the charging circuitry inside the laptop.
Best bet would be to find a similar laptop with a battery that does charge and switch. If the problem follows the battery then you need a new one.
Dec 19, 2007 | Dell Latitude D620 Notebook
Dell Latitude D600 Notebook Logo
65 people viewed this question
Alun Cox
