Proble with Azden Pro radio mic system for camcorder- can t switch receiver on . Power source input & output 9v
Receiver has 9v battery
  • 10,594 Answers
Can you give me its picture?
Posted on Jul 29, 2008
Pro 106. Why will it turn on and scan but produce no audio output with DC power input?
There may be a switch that has to be set for the appropriate power source. Some RS scanners have such a switch inside the battery compartment.
Aug 30, 2015 | Radio Communications
Azden wm pro radio mic system for camcorders- No power going to the receiver. 9v power input.
have you checked the battery contacts of the unit, check for corrosion and possible cracks, best if we isolate the problem firstto pin point specific issue for resolution
Jul 28, 2008 | Audio Players & Recorders
Will the Aux. Input port also work as a earphone system to listen to any audio. This system is in a convertible & this option would be nice going down the road...top down.
aux input is exactly that an input system ( mic , other input device etc)
you need a head phone socket for what you want to do ( output socket)
Jul 05, 2015 | Sony Cdx-gt56ui In Dash Car Cd Player W...
How to remove white noise in my ub802
It can be a number of things.
Bad ground, excess gain, excess number of mixer channels with no inputs, Make sure the mixer inputs you are going to use are the only ones that are up. Power supply noise- flourescent lighting noise, Clamp on ferrites on the power cords of everything can help reduce this. You can sometimes track the offending source with a battery powered AM/MW radio.
It can also be caused by going from a balanced output to an unbalanced input with some impedance differences.
Feb 07, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Have an Aiptek HD 12 1080p with Azden wireless mic system. no sound with wireless mic, but sound works on camcorder without the wireless.
you need to use a mono-to-stereo cable, the azden is a mono output mic by the aiptek is a stereo input and you are shorting out the phantom power with a mono plug in a stereo jack.
- DL
Sep 06, 2011 | Aiptek Cameras
I have TX-SR503 onkyo receiver. I want to connect a microphone to it so that I can do a karaoke. The unit does not have a socket for microphone. It has a socket for phones. This socket does not appear...
The reason that jack doesn't work for a microphone is because it's a headphone jack. It's meant to send a signal out to headphones, and it doesn't work as an input. If the receiver doesn't have a microphone input jack (and it would be clearly labeled as such), you'll need to connect your mike through the auxiliary input. You may be able to connect with nothing more than an adapter to switch from the plug on the end of the mike cable to the RCA jacks on your receiver. The output level on some mikes may be high enough to drive the auxiliary input as-is. More likely, though, the mike will need a little boost to make it work with the receiver. The receiver needs a "line-level" input, which is higher than the output of most good-quality mikes. To get the mike up to line level you'll need a microphone preamp. There are many types from many sources, at a wide range of prices. Here's one I have used as an example.
You might also want to look for a small mixer like this. The mixer would let you combine your mike and music source into a single line-level output you could run to the receiver, and use the receiver just for the amplifier function.
Feb 06, 2011 | Onkyo HTRC180
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
May 17, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Can anybody recommend a shotgun mic for the Sony PDX10 Camcorder?
AZDEN has great quality and affordable price.
THIS is the one I use.
Thanks for using FixYa - a FixYa rating is appreciated!
Feb 13, 2009 | Sony DSR-PDX10P DV Digital Camcorder
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
How to hook wireless mic to canon xl2
Plug it into Audio 1 ports, switch to audio, not mic on the physical camera, then check that you have selected stereo 12 bit, 1,2 from the record audio menu.
Also note you have to push the button next to the audio meter to monitor different sources.
Apr 01, 2008 | Canon XL2 Mini DV Digital Camcorder
 Grubhead
Grubhead
