Kowa TSN-601 Logo
Posted on Feb 28, 2011
I have a Kowa TS 601 with a 60mm Multi coated Lens. There is a small spot about 4mm in diameter on a lens inside the scope, looks like the the coating is blistering. I have been told this is a fungus that started when the scope was stored in a safe. Can this be fixed and will it get worse? Thanks Denis
1 Related Answer
Anonymous
  • 10865 Answers
  • Posted on Apr 22, 2011
SOURCE: I have a Kowa TSN-
hello alexan..... I have first hand knowledge of Kowa and the answer to your question is yes. The company has an east coast service rep. and a west coast rep. Go to the link below to contact one of these service reps.
http://www.kowa-usa.com/kowanewweb/medical/support.html
Joe
How to Spotting Scopes Work?
Spotting Scope is a type of telescope typically used for observing wild animals and birds. A spotting scope features more magnification than a conventional binocular but less than an astronomical telescope.
The utility of a spotting scope becomes most obvious when the identification of an animal going in a large herd is required. Figuring out a specific animal from other look-alike animals becomes easy with such a device. For digiscoping purposes, few things can beat the power of spotting scopes. It is possible by using binoculars or telescopes to take a closer look at birds or other animals, but if you want a precise view of your target animal, a spotting scope is preferable.
Spotting Scope Features Explained
  • Objective lens
    Objective lens, also known as the Front lens, determines the image quality at higher magnifications. The diameter of this lens ranges from 50-100mm in size. It is also called "Aperture" of the lens. It is wise to buy the highest size of the objective lens considering its weight. Larger lenses allow to pass more light and create more bright images. This means you will get higher image quality with the larger lenses.
  • Lens Coating
    Manufactures often apply the chemical coating, which is known as Lens Coating, on the lens to reduce noise and increase light transmission. They also offer "fully coated," "multi-coated" and "fully multi-coated" lens to improve image quality. The premium quality spotting scopes' lenses are multi-coated with multiple layers on the surface.
  • Focusing
    There are two types of focusing mechanism in the spotting scopes such as Helical and Knob focusers. The focusing characteristics determine how quickly you can focus on the object with maximum precision. Between these two options, the helical focuser is the finest option for birding as it can change magnification rapidly along with the movement of the bird. For hunting or spotting slower animals, Knob focuser is best as it gives you more precise information than the former one.
  • Eye relief
    The eyepiece remains at a little distance from the users' eyes. This distance is called the eye relief where the light rays transmitted from the object pass to enter into your pupil. The comfortable eye relief distance is about 15mm to see the full field view. This feature is very important for those who wear eyeglasses. Nowadays, manufacturers are offering long eye relief for those who need to wear eyeglasses for convenient viewing.
  • Image Quality
    You might have seen some designation on the glass label of the spotting scope such ED glass, APO glass, HD glass, Fluorite glass. These special qualities of glass will cost you more but create a huge difference in image quality comparing low-quality lenses. Remember, you must pay for the good quality images when it comes to buying any types of optical instruments.
  • Magnification
    The magnification of spotting scope is higher than standard binoculars and varies between 15x to 75x. The power of the eyepiece determines the magnification of the scope. The important fact you should know that image quality drops off as the magnification goes up. Even premium quality scopes also lose a little quality at the highest magnification.
The condition of the atmosphere has effects on birding, hunting and digiscoping too. Humidity, ever-moving air, dry climates, dust and so on hinders the magnification and image quality at large.
Apr 08, 2018 • Optics
Which is the good spotting scope for higher amount of light?
Bushnell Trophy Xtreme Spotting Scope
Overview
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Specifications
  • Brand:Bushnell
  • Viewing Configuration:Straight
  • Magnification:16-48X
  • Power Variability:Variable
  • Objective Diameter:50 mm
  • Close Focus Distance:25 feet
  • Length:13 inches
  • Weight:31.4 ounces
  • Field of View:125-60 feet/1000 yards
  • Eye Relief/Exit Pupil:16 mm/ 3.1-1 mm
  • Optics Coatings:Fully Multi-Coated
  • Glass:BaK-4
  • Focus System:Focus Knob/Single Focus
Feature Analysis
  • Porro Prism Lens
    Though many optics producers keep on trying to transform roof prism lens, Porro prism lenses are more affordable and light-efficient. These Porro prism lenses can display images with better contrast than roof prism variations. This is how Bushnell Spotting Scope is more reliable and affordable for its high-quality performance.
  • 20-60×65 Zoom Magnification
    The wide range of magnification allows user flexibility for long-range view finding. You can observe details with 65x zoom for long range objects. But, you can still enjoy an increased field of view with 20x zoom. This is used when separating the areas for closer zoom viewing later on.
  • 65x Lens Light-Gathering Capability
    This advanced magnification lenses can light gather at long distances. The Bushnell Trophy 20-60x 65mm Waterproof Spotting Scope resolves this issue by designing 65x zoom lens in a way that brings 17% more light than most high-zoom lenses.
    If you fully read Bushnell Trophy Xtreme Spotting Scope Review, it will support you how to setting zoom for longer distances images.
  • Waterproof Construction
    When you go out in nature, this waterproof construction anticipates you about rain or even snow. It is pretty obvious that any liquid that leaks into your scope will detract from the overall image. But many people do not consider the effects of concentration on the inside of the lens.
    This spotting scope is actually water and fog proof not only for outside moisture but also prevents lens fogging from risky temperatures.
  • Fully Multi-Coated Optics
    The multi-coated lenses prevent any reflections in the glass that can delay your view. The sunlight at certain angles can cause reflections from water or wet surfaces that prevent the clear view of the images. That is why; Bushnell uses multi-coated lenses to remove any kind of reflection.
  • Well-designed Equipment
    The tripod often needs to hide from animals, and the scope cases also need to protect their insides from both jostling and the outside elements. The Bushnell Trophy XLT comes with both a hard-side case and a soft side case. The hard side case protects you from outside damage and a soft-side case protect you from a bumpy road when you are riding.
Mar 18, 2018 • The Optics
1helpful
What are the features of Spotting scope?
Landove Prism Spotting Scope Review Best Spotting Scope In 2018
An overview of Landove Prism Spotting Scope
Everybody cherishes a lovely vacation. Recreational activities like hunting, hiking, wildlife or bird watching refresh our soul. In this case, enjoying a beautiful scenery spotting scope becomes a necessity to have a wonderful sight and captivate such sight in our mobile screens and cameras.
Most of the spotting scope provides this sort of view, but Landove Prism Spotting Scope is unique. We face trouble when we have to carry too many devices and skip perfect glimpse managing those devices. But Landove Prism Spotting Scope is different because it has a space to adjust our mobile phones or camera of such size.
The Landove Spotting Scope review holds the scope's other benefits which are described below.
Specifications
  • 20×60x zoom eyepiece
  • Prism: Bak4
  • Objective lens diameter: 80mm
  • Eyepiece diameter: 20mm
  • F.O.V angle: 1.58 degree-0.91 degree
  • F.O.V (feet /1000yds): 82.9ft-48ft
  • F.O.V (m/1000m): 27.6m-16m
Feature Analysis
Superior magnificationLandove Prism Spotting Scope review states one of its best features which is a 20x60c zoom. With a higher magnification like this, you can click or picture video clips of scenes located very far. But that would not ruin the quality rather it will be clicked with much clarity.
WaterproofWeather can be a great hassle sometimes and mess up our entire plan. But this spotting scope will not let that happen. Landove prism spotting scope is waterproof and allows apprehending the beauty of nature during rain too.
Dynamic lensThe spotting scope has superb focusing system because of its dynamic lens. The lens allows you to have a clear aim and focus on the target.
Fully multicoated opticsThis Landove Prism Spotting Scope review has already stated about the clarity given by the spotting scope. It has a fully multicoated 65mm green film objective lens, superior quality prism, and eyepiece. These specialties let you have a brighter and fresh picture.
Cell phone adapterLandove spotting scope digi-scoping adapter which can adjust your phone to the scope. This adapter helps you to take picture or video clips of the heavenly nature and charming animals without any trouble. For this reason, people all around the world prefer this spotting scope so much.
Standard coating and materialsThe spotting scope is a very light material, but this one is strong enough to be used often. It has a fine design with durability, metal framework and contains rubber armor. The tripod can be attached to the spotting scope which is portable and durable too.
Pros & Cons
Pros
  • Cell Phone Adapter
  • High-quality lens
  • Portable
  • Affordable
  • Easy to use
Cons
  • The Camera lens arrangement sometimes causes barrier for the scope eyepiece.
Final Verdict
Nature always amazes us. Travelling and sightseeing are also required in order to explore the beauty of nature. Spotting scope has become an additional requirement with this. Landove Prism Spotting scope review has remarked all the specialties and a disadvantage of this scope. But this disadvantage can be easily ignored in exchange for such crystal-clear vision.
Landove Prism Spotting Scope has become a top choice for people worldwide because it lessens the difficulties of carrying more than one device. Its features will always increase your excitement and add liveliness to your trip, bird watching or archery.
We can conclude our review by saying this scope is worth purchasing and a great deal undoubtedly. Hopefully, this landove Prism Spotting Scope Review will guide you through the buying process.
Mar 12, 2018 • The Optics
2answers
I have picked up a KOWA TSN-1 for nothing that was going to be dumped and am trying to get it into usable condition. It has a dislodged prism that is rattling around behind the eyepiece.Can anyone explain...
Many of these small spotting scopes are GLUED together. -- not screwed.The scope is NOT suitable for Astronomy, but could be used for birding and or target practice.
Lens needs putting back together
could you please let me no haw to work the ray cop we have no instrutions thankyou sonia holt
Sep 03, 2009 • Kowa Optics
No lens
I am assuming by "lens" you mean eyepieces.
You don't need to get Vivitar brand eyepieces to get additional ones for your telescope. I'm not sure of the specifications for this particular telescope but in general they come in two barrel sizes for the eyepieces. The diameter of your eyepiece is probably 0.965" but could come in the more standard 1.25". You can measure the diameter and determine this quickly.
Once you know the diameter to shop for you can look for the focal length of the eyepiece you wish to purchase. They are rated such as 4mm, 10mm, 25mm, etc. The smaller numbers give you higher magnification. You can calculate the magnification by dividing the telescopes focal length by the eyepiece focal length. For example, let's say your telescope is has a focal length of 360mm and you have an eyepiece rated 10mm. Divide 360 by 10 and that gives you a magnification power of 36.
You can find eyepieces at many telescope dealers on the internet. Your selection will be far less if you use 0.965" eyepieces. You can purchase 0.965" to 1.25" adapters so that you can use the larger eyepieces with your telescope. However, on some telescopes the adapters will cause the new eyepiece to not come into focus.
You'll also find that eyepiece prices go all over the place. A good general purpose eyepiece is a type called the Plossl. The better eyepieces have more coatings too that allow more light to get through to your eye. You'll find these listed with terms like "fully multi-coated".
I hope this helps.
Good luck and clear skies!
-jodair
Mitsubishi Projection TV Model TS 4573 not TS 4545
No if the problem is the screen, you will need to replace the entire screen assembly. some screens come in two parts. The inside of the screen is called the freznal lens, the outside of the screen is called the lenticular lens. Good Luck
Top Kowa Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Kowa Optic Expert? Answer questions, earn points and help others
