Question about Marantz Audio Players & Recorders
I am trying to use the 12 volt trigger on my new Integra preamp to turn on my old Marantz MA700's. How do I do it?
  • 2,071 Answers
At the back of Marantz receiver try to find and output connection of 12 volts,if not you must open your receiver then connect the 12 volts at the output voltage transformer..
hope this may help
DONT FORGET TO RATE:
Regards,
VOTIT
Posted on Jul 29, 2008
I have Sunpak 622 Super Pro Handle Mount TTL Flash. Would it be compatible with a Pentax K50?
Before you attach it to your camera you must check the trigger voltage first, never use an old flash unit until you check the trigger voltage with a multimeter, most old flash units have a huge trigger voltage that will damage your camera.
Very simple to check the voltage on that Sunpak 622, turn on your volt meter and set it to about 200 volts DC, turn on your Sunpak flash and apply the RED lead to the bottom contact, apply the Black lead to the side of the hot shoe and look for the ground, usually a small metal piece on the side. Now look at the meter, if it shows a voltage of 6 volts or less then it is safe to use on your camera, if voltage is higher, say 12 volts or more, don't use it. A high trigger voltage will certainly mess up your camera in the long run. Even if it has a safe voltage of 6 volts or less, you will only be able to use that flash in Manual Mode, the newer cameras will not sync or recognize an old flash unit.
I have an old Vivitar flash unit that I can safely use on my Canon XTI because the old vivitar has a trigger voltage of 5 volts, safe for all newer digital cameras.
Mar 04, 2015 | Pentax Cameras
How to hook up a Marantz AV 8003 pre amp to a carver TFM 45 amplifier
Marantz preamp out, to Carver amp(or line in). Have you tried this and had problems?
Jan 08, 2015 | Marantz Audio Players & Recorders
How to adjust input voltage for marantz 4060 quad amp?
The only way would be a voltage selection switch on the back of the unit, or changing pigtail leads on the primary side of the power transformer.
Apr 30, 2014 | Marantz Audio Players & Recorders
2220 B
Do you mean just crackling generally or it crackles when you turn it up or down? I have a Marantz PM350, old but still great performance, and I periodically take the volume knob off and spray down the hole with a cleaner/lubricant spray. This does the trick!
Jan 08, 2014 | Marantz Audio Players & Recorders
Marantz NR 1403 & Preamp - Volume cannot be controlled by receiver
The newer surround sound recievers will not work no matter what you try with them the way you have it hool up, they are not design to be useing a turn table on them that has a mgnetic cartridge ,Evan if you buy a phono preamp for it, you are just wasteing your time end money, I was a electronic tech for over 40 years ,Before i retired this summer, End no lots of people who tried to do the same thing your trying to do ,End It would not work,
Nov 26, 2012 | Marantz Audio Players & Recorders
Marantz sr 4000 powers up, but no sound
Try plugging in headphones, if they work, it sounds like outputs have blown,
Mar 18, 2012 | Marantz Audio Players & Recorders
I have bose 901 series 2 speakers, marantz 8200 and 2 marantz ma700 monoblock amps how do i hook everything up? Thankd
Do you mean SR-8200? You can't omit the details of a model number if you want a good answer.
Assuming it is...
http://www.retrevo.com/support/Marantz-SR8200-Receivers-manual/id/511ci775/t/2/
Run the 901's with the Active EQ between the receiver Front L and R Pre-Outputs and the mono block amps, one chanel to each.
Pre Out Channel X >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> Monoblock IN
http://community.klipsch.com/forums/storage/74/1341919/200w%20mono%2005.jpg
I can't find a manual for the MA700. Set them up to a certain volume and then use the speaker setup routines of the SR to match everything up volume-wise. Control will be in the AVR.
Aug 22, 2011 | Bose 901 VI Main / Stereo Speaker
Protect appears on front panel
it is possible that one or both outputs have gone d.c.. try disconnecting both speakers and check across left and right output terminals with a d.c.voltmeter set to 100 volts. no d.c. volts should be present
Feb 04, 2010 | Marantz Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
Can't find replacement bulbs
Unit probably uses fuse type lamps, either 8 or 12 volt filament. Remove one of the lamps and look for voltage rating on end cap. You can order these lamps from Allied Electronics or MCM Electronics online
Jun 06, 2008 | Marantz Audio Players & Recorders
121 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
