Question about Mitsubishi WS-55859 55" Rear Projection Television
Need a Receiver! can you Help?
I purchased this TV used and I want to buy the "Mitsubishi HD-1080 HDTV Receiver" to convert it to HD but I can't find one. Does anyone know where I can find one? Post Solution Work Queue --> Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by jgruen2681, posted on Jul 29, 2008 Does anyone have a Receiver like there talking about to sell?? Thanks Randy
I HAVE THE AME TV AND I DID NOT HAVE TO GET A HDTV RECEIVER BUT NOW I GOT GREEN SHOADOWS IN TV WHAT COULD THIS BE?
Posted on Aug 18, 2008
Mitsubishi ws-55805 HDTV Control to HDMI
there is a converter box , where you can connect everything and convert in to hdmi output , you can buy this boxes on the internet or at the redioshack
Feb 12, 2012 | Mitsubishi WS-55315 55" Rear Projection...
I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Mitsubishi WS-65313 65" Rear Projection...
I bought a used mitsubishi ws 55513 and when i turn the tv on is says 480i stretch. How do i use the 1080?
U don't get to chose modes.480,720 and 1080 it chose by the tv show itself.Want more 1080 must have HD package from cable or satalite compannies.
Jan 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Unlock parental control
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Apr 01, 2009 | Quasar SP-2722 27" TV
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Connecting TV to cable service for HDTV
normally you need a converter box for hd because normal stations are broadcasted in hd.....its not common enough for them to do it...and you probably have to buy a package with your cable company for the hd channels. another thing...is your tv hd ready?
Sep 30, 2008 | Mitsubishi WS-48313 48" Rear Projection...
Need a "Mitsubishi HD-1080 HDTV Receiver" to convert my TV to HD
You con't need to buy anything other than a HD satellite or cable box. A television can either handle HD or not.  The high definition sets are monitors that are capable of handing an input of up to 1080i.
Quick and dirty. Look in the back for blue, green, red cable input sockets. There should be matching cable outs. from your cable or satellite box. get a set of  component video cables, plug them in. Determine the audio type, where RCA jacks, Toslink fiberoptic or a component cable sock. In the latter you use a cable much like a yellow video. You can get away with using a yellow video cable if need be. Now, below more specifics if needed.
No, you don't want to by the add-on from Mitsubishi.  I am assuming you have a 16-9 wide format box
If you have a squarish box, i.e. 4:3 ratio. forget it. I don't know if any wree made for HD, but unlikely.  If you'd given me the model number could be a little more definitive. If you have a manual, it will tell you whether you can go HDTV.
Take a look in the rear of the set and look at  the connection holes. You should have at least one set of inputs, marked in some way with the Red, Green and Blue just on the inside of the cable hole. Those are tomponent cables pops that allow you to do high definition television. These cables are video only.; Sound is a second separate question.
There are usually some other assorted things back there, including off air tele.and maybe another kind of connecter.. Some of these might be useful if you have games etc. that attach directly to the set. In any event, those component cables say that you can  do HDTV. (NB:
The Direct TV  HD box should have component cable outputs. You can do this directly from the DiTV box to the set. You would also need a separate Audio Cable(s). Your set should have either a toslink fiberoptic hookup and/or a component audio cable. There's no inherent advantage between those two. If you have an old video cable (yellow) than you can substitute that.
You should now have HDTV and high quality sound through the set. You will probably have to set up the inputs and other stuff with the.remote. It's pretty logical. If you have used input x for bringing in the video, just match it up.and your on your way.
If you are going to confuse things by trying to connect another piece of gear, e.g. dvd box, you would go to inputs two. If you have the second set of component input, then hook an HD player to it. In this setup, you adjust the sound on the set according to how it works. I assume the DTV audiio can be controlled directly just as a cable box.  -- Here's what's going on. For several years Mitsubishi built higher end televisions without tuners or slots for cable (or satellite). But they were HD capable (as I said, not all). At the time, there was no HD that mattered and not even much of a standard for it. Some wanted 729p, others wanted 1080i The advantage for 720p over 1080i was supposedly the improved movement capture. 720p isn't dead, but it's not a problem.
You will need to set the menu on the television (using the remote) so that it says 1080i. It does not do 1080p, the newer high standard. It only has two other settings of consequence, 480i and 480p. Put it on 1080i and leave it alone. The 480i and the 480P will be on auto pilot if you have an older DVD players. If there is a high definition signal at fewer than 1080, it will be upconverted to 1080i..
The set will handle any signal you send it like that. You probably have an HDMI  out from your dtv or cable box. The set does not have HDMI (unless on a later model). The DTV box should have both of them. That's a simpler wiring setup that allows 1080P. On the offchance you have a box HDMI only, you'll need a converter cable.
The setup gets a little more  complicated if you're using a receiver as a switcher, i.e. all inputs go there with only one output to the set. when ou do that you're in an area outside this question.
  is this all there is to it. But It goes only slightly more difficult if you're hooking up the   .
You don't need the box for the television set.
Feb 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
1080 VS 480
Trash can it and buy a new T.V.
Jan 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Upgraded DirectTV satelite TO HD
direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
