Question about Goodman CKL60AR60 Air Conditioner
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The ac unit will freeze outside on the larger copper pipe running from the house to the unit (Low Pressure Side?). The fan motor in the attic will kick off but the outside unit continues to run. There is frost on the copper pipe I mentioned before. If I cut everything off for about a half hour, it will work normally for awhile but will eventually freeze up again. It actually seems worse on the cooler days than on hot days.
I had the freon pressure checked on the low side and it was 70. Apparently it isn't low on freon.
  • 3,361 Answers
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Posted on Oct 02, 2011
AIr flow is good. New filter.
Posted on Jul 29, 2008
  • 182 Answers
Sounds like an airflow issue.How is your filter?Blower wheel clean?Depending on the temp in the house,70 suction could be low(very unlikely)
Goodman ez-1425 ac copper pipe keeps freezing up
copper pipe freezing on the outside indicates that there is liquid evaporating in the space created by the suction of the compressor
the pipe normally will be insulated to stop atmospheric humidity condensing on the pipe
Suggest that you get in a technician to check gas pressures and ac operation
Aug 06, 2016 | Goodman Heating & Cooling
Honeywell how to install
Did you try E too aux and x1 to c?
Jul 20, 2014 | Honeywell RTH6580WF Wi-Fi Thermostat
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Cold air out of top outside unit but no cold air in house
Hello touch the two copper pipes entering the outside unit, the larger one should be cold with condensation the other one should be warm. If not the unit has no refrigerant in the system or the compressor is not running.
May 20, 2012 | Heating & Cooling
Have a Goodman AC unit (model: GSH130421AA) in my two story town home. The upstaris does not cool, however, downstairs does. The outside pipe(?) that leads into the AC unit was frozen; looked like a snow...
Hello, when the pipe freezes up it usually indicates a airflow problem or low refrigerant charge. Check the air filter, blower wheel for any dirt. Also, make sure the blower motor is running. If the airflow checks out good then the unit is low on refrigerant and must be recharged by a hvac technician.
Jun 04, 2011 | Heating & Cooling
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
Not cooling house it stay on unless you turn the thermostat to 88 degrees
if the the outdoor unit is running and the larger of the two copper lines going into the unit from the house is not cold you are probably low on freon. if the line is iced up then you need to shut if off for 8 hrs and try again, make sure the filter is clean recheck the large copper tube again if its not cold your probably low on freon. if its not running at all outside check your breakers. there are a number of diffrent things that may be wrong and you probaly need a service company to look at it.
Mac
Sep 22, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
879 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
