Re: Peavey KB100 75 watt keyboard amplifier. Dear Sir, After having plugged into the 'PRE EQ PATCH' the main 3 inputs/channels are no longer working. I looked in the operating guide and found that, "If the second click of the Out/In jack is utilized without returning any signal to the system from an effects device, the remaining preamp functions will be disabled." (and disabled they were!) It doesn't make any real sense that it would be simply that easy to damage the amp. Awright now, what is it that I have to do to 'restore' the remaining 3 inputs/channels. Your help would be gratefully appreciated. Sincerely, Patrick MacCarroll 313-570-3185
Patrick - There are surface mounted input jacks on a lot of Peaveys. The jack (effects loop/pre-EQ ) jack may just be dirty or stuck. Try spraying the jack thoroughly with electronics cleaner (Radio Shack) and work a plug in and out of the jack.
Posted on Jul 29, 2008
  • 4,234 Answers
The pre-eq patch connector is a 3 -wire connector designed as both an input and output in one connector. With a plug in there that only utilizes the output (send), you are not sending any signal to the amp section. That appears as no output. Take out the cable and the amp should be restored to original function. What you need to use that function is called an "insert" cable. This has a stereo 1/4" plug at the end for the "pre eq patch" side and 2 standard 1/4" plugs at the other end. One is for input into an effects box and the other is for the output from that efects box.
Hope this helps,
I have two peavy xr 600b i want to daisy chain them so i can use one for the monitors how do i do that?
you will need 2 y patch cables 1/4in to make this happen, they need to be about 3 ft long, set one head on top of the other...then use a y patch cable and plug it into the main output on both heads, then plug it into the graphic input on the head you want to use for the mains....then take a y cable and plug it into the monitor output on both heads...then plug it into the graphic input of the other head, this one will run the monitors.
Apr 27, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
How do i use the effects loop on peavey xr 600b?
plug the effects out into the input of your reverb/echo unit, plug the out put of the processor into an unused channel in the mixer, do NOT turn up the effects in that channel, to hear the effects in the main use the main level, to hear effects in the monitor use the monitor level. you must turn up the the effect send in the channel you want to hear the effects on and also the effects master.
Jan 23, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
I have four bose 901 speakers and one equalizer. I also have a peavy deca 424 amplifier. I have a tape deck with the tape monitor capabilitity. Can these work together and how do I hook theme up?
The presence of 1/4" TRS balanced phone jacks instead of RCA inputs is a problem; and the 1/4" TRS speaker output jacks, too. You'll need to acquire cables with compatible ends.
The amp can handle 4-ohm loads so running two 901's parallel on each channel would theoretically work, but I'd put them in series just to keep from presenting too low a load when you get cranking. At 230 wpc you've got the juice. From Series 4 on the 901's are very efficient.
The Tape Deck will attach conventionally to the Tape Loop on the Active Equalizer.
Once you get the physical wiring compatibility issues worked out:
Patch the Active EQ directly between any source you may be using (Amp In from the Pre-Out of the source, Amp Out to the Peavey input).
You can record the external source onto the attached Tape Deck and you can monitor it by pressing the Tape switch on the 901 EQ.
Start out at low volume and see how it works before turning it loose.
Dec 28, 2010 | Bose 901 VI Main / Stereo Speaker
My Peavey Mark 3 400 CHANNEL 1 does not put out sound. When you turn the pre gain it will cut in for a sec then out. Channel 2 is good. I checked the readings on the pre gain pot on channel 1 and 2 and...
Transfer Channel 2 speakers to Channel 1 to check if it does put out a sound. If it does, it means that your Channel 2 amplifier is defective. However, if it doesn't,
then your Channel 2 speaker is defective. So, have this checked to find out the result. Defective items needs replacement or be repaired. Send us your e-mail for the result so we can further extend our assistance.
Oct 13, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Feb 25, 2009 | Yamaha MX-D1 2-Channel Amplifier
Connecting Bose 901 series iv to Harman Kardon AVR 254
Most HK av receivers have pre amp out,power amp in with metal jumpers connecting them for the main or front channels. that would be the best place to hook up the EQ on a AV receiver. If your receiver doesn't have pre out, power in jacks , you can use tape monitor .record out playback in. The tape monitor option is best for stereo use , as the active EQ will charge all speakers in tape mode, possibly damaging other speakers.I run my 901 s with a seperate pre-amp,power-amp hooked up to my Denon AV receiver that way i can run in surround w/standard speakers
Jan 06, 2009 | Bose 901 VI Main / Stereo Speaker
How do I connect my bose 901 active equalizer to a onkyo tx-sr506
AV receivers are notoriously incompatable for Bose 901s. The problem is the EQ charges the entire system and could damage the surround processor. Some higher end AV receivers, including some of the newer Onkyo models have pre out power in inputs on main or all seven channels.which you could install your EQ directly between pre amp & power amp without damaging processor. You can also add a two-channel amplifier to the pre out jacks front channels and use your recever's remote to control volume.
Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
801 people viewed this question
