Question about Epson DFX-9000 Matrix Printer
Seeting top of forms for EPSON DLQ-3500
I have already adjusted the TOP OF FORM to the maximun level ad according to the manual I've downloaded, it it reaches the maximum adjustment it will beep and stop adjusting, but my problem is, I need to adjust it a little more so the printing will fit my invoice form, is there a possible way to alter or adjust the top of form level a little more even if it reaches the maximun level
4 Suggested Answers
  • 8 Answers
SOURCE: the contents no in the right place
check the ink. check to see to the file fits the paper in print preview mode. if you still have problems take it to best buy.
Posted on Feb 10, 2009
vanherringto
  • 1738 Answers
SOURCE: where do we find 64 bit driver for dlq 3500.
A 64-bit driver is not available for your Epson DLQ 3500 printer and none is expected to be released.
The only driver available for the EPSON DLQ-3500 is for Windows 95/98/ME/2000/NT4.0
Posted on Feb 05, 2010
SOURCE: PRINTING TWO EXTRA LINE ON
Windows 7 x64 & LQ-570+ ESC/P2 @EJL solution (should also work for other printers/OS, but not tested yet):
Try modifying .dpg file.
STEP 1:
Print the windows test page.
STEP 2:
There should be written the location and name of the file (Data file), so print the test page and look up the file path. It is located in the sam folder as dll (config file). In my case it is in "C:\Windows\system32\spool\DRIVERS\x64\3\".
(Sience I coulden't find x64 driver for LQ-570+ ESC/P2 I used LQ-590+ ESC/P2 Ver 2.0 driver. It's working ... )
STEP 3:
Now, when you found .GPD file, (make backup copy just in case) you have to add your computer account to list of accounts that has full controll of file or you won't be able to save changes.
STEP 4:
Delete only @EJLl 1284.4 and @EJL in line that looks like that:
*Cmd: "<0000001B01>@EJL 1284.4<0A>@EJL <0A1B>@<0D1B>t<011B>6<1B>R<001B>P<1B>(U<01000A>"
(If you delete anything else at that line it won't work ...)
STEP 5:
Save file an enjoy printig :P
If you have any question, write to riddle.xyz@gmail
Posted on Oct 21, 2010
caroldon
  • 17129 Answers
SOURCE: Printer EPSON DLQ 3500 prints
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed.
Sometimes it is possible that the head is not reacting to the need of the PC command
Posted on May 06, 2011
How to set ip address for epson dot matrix printers
How to remove the ip address,for dot matrix printer?
Feb 06, 2012 | Epson DLQ 3500 Matrix Printer
Printer EPSON DLQ 3500 prints only at right side of the page in 3" area, not prints on whole page.
May 06, 2011 | Epson DLQ 3500 Matrix Printer
How can i download for an Epson Stylus T10 printer driver cause i lost the driver cd? Thanks
Hello and Welcome to FixYa!
You can download the Driver according to your Operating System (Windows XP, Windows 7..) from the Vendor's website. Kindly navigate to this link, select the OS from the top drop down menu and the available drivers will be shown.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Mar 25, 2011 | Epson Office Equipment & Supplies
I am trying to print on forms that are tractor fed and are 8 X 5 1/2, how do I adjust the printer so it will print on this size form. How do I adjust the printer to this size. I have already adjusted in...
select file at the top left hand corner of the page from the drop down list select page setup you should see a margins box you can make your adjustments in this box left.right.top.bottom also you might select print preview where you can look at the size and detail of the document you are about to print
hope this helps
Nov 24, 2010 | Office Equipment & Supplies
I lost my instlation sofware can i download it form the internet
here it is : http://www.epson.com.ph/epson/drivers/driver_download.htm?mode=3&catid=4&productModel=4&catid=&pid=873&ad=1&downloadType=Windows
Oct 28, 2009 | Epson Stylus CX4700 All-In-One InkJet...
Oki 3320
There is no easy way. You need to adjust starting position for every form. There is fine feed function and Top Of Form setting procedure, so you can adjust the minimum space between top of porm and first printed string (user's guide explains in details how to do it). But after that you need to decide whether you manually set the start position by rotating the knob or play with your application to adjust margins etc.
Dec 24, 2008 | OKI MICROLINE 3320 Matrix Printer
Printing multi copy forms
you can check your paper size or the tear of poit and set it to that point.
Oct 01, 2008 | Epson FX 890 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
