Question about Microsoft Xbox 360 Console
I need help
I think my lens needs cleaned and i have a lens cleaner but it says not to use on a regular xbox does that mean the 360 to.
    Sergeant:
    Champion:
  • 452 Answers
Try it, you have nothing to loose at this point.
Posted on Jul 29, 2008
    Problem Solver:
  • 9 Answers
Yes, it does, so don't use it...what part of the xbox360 do you want cleaned?
Xbox 360 arcade is not loading any discs
ok when such thing happiness it means the lens is weak or dirty to read any disk. so first get a lens cleaner, it comes in a form a disk with a liquid solution use it to clean the lens.
or get your lens replaced.
hope it help.
Sep 17, 2012 | Microsoft Xbox 360 Console
It will start reading then it stops
Clean the disc and clean the laser lens in the Xbox with a laser lens cleaning kit.
http://www.gamestop.com/xbox-360/accessories/xbox-360-cleandr-laser-lens-cleaner/93068
Good Luck!
Jun 10, 2012 | Microsoft Xbox 360 Console
I think my lens is weak, the cd has to be ejected and inserted a couple of times before it works
Like any system, Xbox consoles require occasional cleaning to remain in peak condition. If you're experiencing skipping, poor sound quality, increased loading time, or any number of technical annoyances, simply cleaning your Xbox lens may correct the problem. The lens is responsible for reading all the data on your Xbox game discs; it is the most important part of the entire system. Cleaning the lens takes only a few minutes with the right cleaning product and know-how.
Difficulty: Easy
Instructions
Things You'll Need:
* CD lens cleaning disc
1.Purchase a CD lens cleaning disc. It is important that you buy a lens cleaner for a CD player, not a DVD player. Classic Xbox consoles are not DVD compatible, but they can play CDs. Some lens cleaning discs are marketed specifically as Xbox 360 cleaners, but these may not work in an original Xbox if the disc is DVD-formatted.
2.Turn on your television and Xbox just like you normally would to play a video game.
3.Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
4.Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
5.Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
6.Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
7.Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console
Aug 19, 2010 | Microsoft Xbox 360 Console
My xbox 360 lens is drity how do I clean it
There are a few ways.
1.Use a CD Cleaner, it looks like a regular CD but has brushes on the bottom of it.
2.Can of compressed air w/nozzle extension. Open the CD Tray and pull the power from the wall so that the tray can be moved around. Push the tray about halfway in then insert the nozzle to right above the CD Lens and give it a few shots of air. A flashlight can help with finding the lens.
3.Disassemble your 360, do not forget this voids any warranty. Once you have the case open, take out the CD Drive. Open it up, get rid of any dust and clean the lens really good. While it is open, clean out the fans, vents and heat sink which will help with cooling.
Hope this helps.
Apr 06, 2010 | Microsoft Xbox 360 Console
My game wont read on my xbox 360
I believe you can use a DVD cleaner without voiding your warrenty. If you have a warrenty then call Xbox tech support to get it fixed. And if you don't buy an extended warrenty for $50 and then call them and tell them you need your Xbox fixed
steps to be followed.
  1. step 1 Purchase a DVD lens cleaning disc.
  2. Step 2 Turn on your television and Xbox just like you normally would to play a video game.
  3. Step 3 Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
  4. Step 4 Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
  5. Step 5 Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
  6. Step 6 Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
  7. Step 7 Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console.
Jun 13, 2009 | Microsoft Xbox 360 Console
360 wont read discs
The lens either need cleaning with a disk cleaner or the lens will need to be replaced.
jonno
Sep 02, 2008 | Microsoft Xbox 360 Console
Disk read errors
Try to use cd rom lens head cleaner, the one with the small brush at the middle of the disk, never use cleaner using liquid solution. the best cleaning method is to open the cd and clean manually the laser lens using a cotton buds, the lens are so delicate so don't apply too much force. you can easily locate the lens in the cd case, it is a round bluish lens. cd rom cleaner works best when your unit is clean!! Huhh? Run it once a day, regularly, its like sweeping the floor of your house before you work for that day. Cd rom cleaning depends on playing back the No 1 and jumps to no 3 tracks, cleaning takes place on track 2 of the disc, you cannot clean if you cannot play the unit.. get that?
May 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
