Question about HP Computers & Internet
Hi i have a hp pavillion dv6700 it froze last night.I usually use th finger print scan and not the password.I restarted th laptop but the finger print scan doesnt work and i cant remember the password to get into the laptop i dont think i even used a password.I was wondering if there is a way to by pass this so i can get into the laptop and fix what went wrong.I dont have a recovery disc.Im on my old laptop atm and was wondering also if i can make a recovery disc from this laptop to use in my other laptop.Any help would be appriciated.Thanks Sandi
  • azure1 Jul 29, 2008
    Thank you i do appreciate your comments and yes i could be anyone.Im not that computer savvy and im just learning lol.I did ring HP and i am doing a full recovery.Thankyou Azure1.
    Guru:
  • 859 Answers
Hi, Sorry but we are not allowed to help people circumvent passwords or disable them. We have no way of knowing you are the laptop owner. Do you follow me? This is for your protection if this is your laptop.
You will have to contact HP directly and or the fingerprint scanner manufacturer yourself. On the back of your HP laptop is a Service Tag that sort of looks like this one.Hi i have a hp - e424f16.jpg
Once HP is satisfied, you can receive instructions from them.
The only other way is to remove the wrist rest and keypad bezel carefully. It has a sensitive ribbon cable attached to the mainboard, don't let this become detached. Inside the mainboard is a battery pack that has a red and white wire. You disconnect the wire plug from its socket with A/C power removed and your battery out. Leave this plug out for several minutes. Replace it, replace your wrist rest and keyboard bezel and insert your battery, attach A/C power and boot up, immediately press and tap F10 to enter the Setup Screens. You will need to set the time and date and at the bottom of the screen will be a keyboard legend that will tell you which F key loads setup defaults, usually F9. Leave the fingerprint scanner off your system and seek advice on how to reset it to none from the manufacturer. Although most of these devices comes with a small CD to setup the scanner.
Hope this fixes your issue.
Regards,
Worldvet
Posted on Jul 29, 2008
    Brigadier General:
  • 6,966 Answers
An alternative is to boot/run a diskette that is meant to delete whatever password is saved in your Operating System. It is basically an "Offline NT Password and Registry Editor". Download, decompressed and install in a floppy drive.
Password delete
Simply follow on screen instructions and answer YEs to most (if not all) of the questions.
I believe there is also a CD version.
This same solution was also posted by another expert here at FixYa.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 29, 2008
    Hi again,
    Here is the CD version. It is an iso image and must be burned into a CD. Like the diskette version, it will be bootable (hence boot on CD) and follow on screen instructons and/or Yes to most of the questions. All others should and would be self-explanatory once you run the program.
    Cheers.
    Guru:
  • 1,894 Answers
Clean then scanner with a cloth dipped in alcohol and clean it
  • dewan nafees ahmed Jul 29, 2008
    clean the finger print scanner and check if you can make some improvements.
    if not then try creating a recovery disk in another laptop and use it in your laptop to start a recovery session.
HP Pavilion dv6700. no screen.
Please run system restore to an earlier date.
Start system holding down f11 key till you hear a beep then follow the screen instructions.
Good luck.
Mar 21, 2010 | HP Pavilion DV6700T Notebook
HP Pavillion DV6700 is shittung down
This could be numerous things. It could be an over heating problem, a virus, a power supply failing or something wrong in the power adapter on the motherboard where the power plug plugs into the laptop. If you plug in the laptop and see the battery charge light come on then the problem is most likely an overheating problem or a virus. If the battery charge light comes on then I would recommend taking it to a reputable repair facility to have them diagnose the problem.
Jan 01, 2010 | Computers & Internet
Pavilion dv6700 AC Power. My DV6700 performs perfectly on battery, but will not charge the battery or run straight off AC. AC Adaptor, Batteries and AC jack have been tested in fine working order. Any...
Hi, believe it or not?; sometimes the current in certain areas of the home or apartment have separate power circuits from the main direct current system. Check to make sure there is electrical current running through your socket, and or light switch to open the circuit. Thanks, paul7of9
Dec 29, 2009 | HP Pavilion dv6000z Notebook
Hi my HP Pavillion dv6700
i think you should use USB keyboard.
Feb 02, 2009 | HP Pavilion DV5234US Notebook Laptop
HP Pavillion dv6700 won't load up - gets stuck on logo page
i afraid that cause by hardware, but try to remove battery and only use the power. or press F2. if prsseing f2 the new screen(bios) open try restart and press F8. tell me is it work or not
Jan 28, 2009 | HP Pavilion DV5234US Notebook Laptop
Computers & Internet Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
