Question about HP Computers & Internet
My hpdx5150 MT is having problems. when i start it up it turns on, but the monitor stays off. im not sure what to do. is my moniter broken, or id it the computer base
    Problem Solver:
  • 26 Answers
U need to first check if the signal cable is connected well.
check that the monitor is receiving power.
if so then maybe the vga card of the base unit is the one with the problem.  may need to put in another one to check if the oe ur having is the one with a problem. try that and get back to me.
thnx
Posted on Jul 29, 2008
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
May 21, 2016 | Dell E172FP 17" LCD Flat Panel Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
The monitor will turn on but only stays on for about 3 seconds
Maybe you guys should make sure the moniter is on the right input, because if moniters are on a wrong input then they go into sleep mode. If that doesn't work make sure that the cables are fully inserted! Hope I Helped!
Jan 20, 2009 | HP Pavilion F1703 17" LCD Monitor
Scanport N7 LCD Monitor won't stay on
it seems a whole lot of people have moniters with fatal ailments as i do as well. after spending $ 150.00 at computor stores & still had the same problem with my Moniter I just orderd another new moniter & the Problem is fixed..
I Think there killing moniters on purpose
Jan 15, 2009 | Scanport 17" LCD Monitor
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
Moniter Display
THATS THE SIGN OF A CORRUPTED CHIP BOARD IN THE MONITOR ITSELF THERES NOTHING YOU CAN DO IM SORRY TO HEAR THIS
Jul 01, 2008 | Gateway FPD2275W LCD Monitor
My Acer LCD AL1711 went off after seconds of turning on.
This monitor has "back lights" that are essentially like flourescent lights. These are high voltage lights and can easily fail. since you are getting some light initially, I would suspect a defective part that heats up a bit right away and then fails. I would try to replace the entire backlight board. This is the small board on the side (usually).
Dan
Mar 27, 2008 | Acer AL1711BM (Black) 17" LCD Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
