Question about Singer Inspiration 4210 Mechanical Sewing Machine
Upper thread wraps around bobbin mechanism, while sewing
No issues pulling up bobbin thread to meet up upper thread.
While sewing, upper thread gets completely wrapped around the bobbin mechanism, thread tightens up, and can't move forward with sewing.
Tension @ 'auto' setting and both upper and bobbin threads are threaded correctly.
What can be done to fix this problem?
  • 10 more comments
  • got2keepmovn Jan 26, 2009
    I have the same problem. The machine IS threaded correctly and has been cleaned. The upper thread wraps around the bobbin casing.
  • jhietikko
    jhietikko Mar 30, 2012
    I have the same problem... seems like it's a recurring issue with this machine... is there a fix?
  • Anonymous Mar 12, 2014
    bobbin thread just pulls out
  • Anonymous Mar 14, 2014
    the thread goes around the bobbin
    I can't tell if I have it threaded correctly
  • Anonymous Mar 17, 2014
    I have a babylock quest I can sew a foot then the bobbin thread loops around the shaft that holds the bobbin. What can I do to fix this problem
    top thread getting around the bobbin
    sews four stiches then does not pick up bobbin thread for a few
  • Anonymous Mar 22, 2014
    Bobbin Thread gets bound up, and Tension is not functioning as it should. I can clean it up and it works for awhile, yet returns to create problems. In addition it keeps beeping at me as if it doesn't like the way I'm sewing, so I have to turn it off and back on again to continue.
  • Anonymous Mar 27, 2014
    Bobbin thread not sewing. There is nothing moving inside the machine around the bobbin case.
  • Anonymous Mar 29, 2014
    wan,t sew
    upper thread go around bobbin
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
Thread balls up885-v60-v61v63-v64- v65 ce1100prw sewing machine brother sewing machine modelCE1100prw
If it is creating a thread mess (thread nest) under the fabric, either the machine is not threaded correctly or you have forgotten to lower the presser foot before beginning to stitch.
Make sure you are starting with a brand new needle!
Remove all the thread from the machine.
Check that the bobbin thread is smoothly wound onto the bobbin and that the bobbin is inserted and thread properly in the machine.
ALWAYS RAISE the presser foot and rethread the upper thread. Check that the thread path is correct.
Set the upper tension to the midway point on the dial--this is usually the factory setting but may alter over time with use. Once you get your machine stitching without a mess, you can gently alter the upper tension until the two threads meet in the middle of the fabric.
Remember to lower the presser foot before beginning to stitch.
It also helps to pull the bobbin thread up to the top of the fabric and either wrapping both thread tails around a finger on the left hand or gently holding the thread tails between the left index finger and thumb. Then SLOWLY begin stitching.
How and Why to Bring up the Bobbin Thread
You can search the internet for:
YouTube + Make + Model
and hopefully you will find some helpful videos.
Sep 26, 2016 | Sewing Machines
How to fix a thread correctly on a Toyota sewing machine model 5500
You don't state what is the problem with the thread so we are unable to provide helpful suggestions.
As a starting point, make sure to install a brand new needle that is compatible with the thread & fabric you are sewing.
All About Needles
Second, always raise the presser foot while threading the upper thread.
Make sure the thread path is correct (consult the owner's manual), insure that no thread guides are skipped or the thread is not wrapped around something it shouldn't be.
Set the upper tension at the midway point between low & high numbers to test stitch. Tension is correct when both upper & bobbin threads meet in the middle of the fabric.
Understanding Thread Tension Threads
Apr 12, 2016 | Toyota Sewing Machines
Why does bobbin cotton keep bunching?
Is it the upper thread bunching under the fabric? If so, it is usually incorrect upper threading, the thread is not seated in the tension disk, or the upper tension is too loose. Also, a damaged needle can cause issues.
Install a brand new needle that is compatible with the thread and fabric. Frequent changing of needles is an inexpensive fix for a frequent sewing issues.
All About Needles
Remove all the upper thread.
RAISE the presser foot and rethread from the beginning.
Make sure the thread path is correct (consult the manual).
Set the upper tension at the midway point between high & low numbers.
Retest. If the upper thread and bobbin thread are not meeting in the middle of the fabric stitched, then loosen or tighten the upper tension until it does.
NOTE: Always thread the upper thread with the presser foot in the raised position. This opens the disk and allows the thread to seat properly. Also to remove upper thread, it is best to clip the thread near the spool, raise the presser foot, and graspl the clipped thread tail near the needle and pull DOWN through the machine (Never pull thread up through the tension disk).
Noted that you cleaned the bobbin area, but also be sure to clean the feed dogs. Frequently, lint & dust accumulates in and around the teeth which can inhibit their ability to grasp the fabric firmly. Frequent cleaning in this area is important for your machine's maintenance.
Review the cleaning and oiling instructions in your manual. Oiling is important and should be performed frequently with 1-2 drops each spot as specified. Oiling the hook is usually good to do every 8 hours of sewing time. Use ONLY fresh good quality sewing machine oil for your machine--NOT 3-in-1, WD-40, cooking oil, or the old metal can in grandma's sewing basket.
Feb 22, 2016 | Sewing Machines
Why does the thread keep wrapping around the arm that goes up and down.
improper thread tension (knob on back) or its not being wound thru the tension device correctly ??
Jan 18, 2016 | Sewing Machines
Model 820ex. Why does it have thread nesting, thread breaking, and uneven tension?
You might try cleaning the tension disks by dampening a length of pearl cotton with rubbing alcohol, open the tension disk all the way, raise the presser foot, and then pull the pearl cotton down between the disks a couple of times.
Clean away the lint and thread pieces from the feed dogs and bobbin area. Oil your machine according to the instruction manual--use only fresh good quality sewing machine oil--only 1 or 2 drops of oil each place.
Install a brand new needle. Make sure you are using a needle and thread that are compatible with the fabric you are sewing--that the thread is not too big for the needle's eye, etc.
All About Needles
Make sure you RAISE the presser foot BEFORE threading the upper thread. Rethread the thread from the beginning checking that thread is not wrapping around the spool pin or catching somewhere in the threading sequence.
Verify that you are threading the machine correctly. Misthreading will cause havoc and frustration!
Do not use old or bargain bin thread--Coats & Clark does create problems for some machines.
You might try pulling the bobbin thread to the top before beginning to sew. This helps prevent some of the thread nests you are experiencing.
The factory tension setting is usually the halfway point between the high and low number. This is where you should start testing your tension. Once you sew a sample, if the top thread is looping/knotting (bird nesting) under the fabric, the upper tension is most likely too loose. If the bobbin thread is pulling to the top of the fabric, the upper tension is too tight. Get used to adjusting the upper tension every time you change fabric, needle, thread. The upper tension is not meant to be static, so don't be afraid to adjust to achieve the proper tension.
Ideal tension is when both the upper thread and bobbin thread meet in the middle of the fabric.
Dec 13, 2015 | Elna Sewing Machines
Why is the top thread wrapping around the bobbin case and not pulling the bobbin thread through?
The hook pulls the top thread half way around the bobbin case and then the slack arm pulls it the rest of the way around. The slack arm is in the upper part of the machine barely visible on newer machines, but you do hook the thread thru it while threading the machine. If your thread doesn't go thru the tension discs or the tension is very low, then the slack arm has nothing to pull against, like a tug of war where the guys on the other end of the rope let go!
Try pulling on the upper thread before the needle and be sure the presser foot is down (up releases the tension). Adjust the tension and you should feel a difference.
Dec 01, 2015 | Sewing Machines
So when I start sewing it works for a few seconds then my top thread breaks and or wraps its self around the black casing the bobbin sits in. What am I doing wrong?
Be sure to RAISE the presser foot BEFORE threading the upper thread. This releases the tension disk so the thread can seat properly. If upper thread is breaking soon after beginning to sew, it usually is because the upper tension is too tight. Try loosening it and re-testing. The upper and lower threads should meet in the middle of the fabric.
Sep 21, 2015 | Singer Pixie Plus Sewing Machine
Brother pc 8500 upper thread breaks
Check the spindle the thread is mounted on and see if it\'s wrapped around it. Sometimes thread will catch and wrap around the spool spindle and break.
Check thread guides to be sure there are no nicks that might be catching the thread or damaging it.
Replace the needle.. a burr in the eye can cause upper thread to break. Needles should be replaced often, modern fibres can be hard on them, they get dull and that\'s no help for anything either.
Make sure the thread spool is mounted on the spindle with the thread coming off as directed in the manual. Some machines only work when the thread feeds in the right direction from the spool.
It can also be a tension issue.. tight upper tension or tight bobbin tension. Bobbin tension may be adjustable manually, but it\'s pretty rare for it be a problem. Upper tension, I don\'t know. I\'ve yet to get into computer machines so am not familiar with how they set upper tension.
But the mechanism that produces the tension can wear out or break and need replacement.
Jun 25, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Singer 3820 Bobbin Issues? I can't sew!
Unthread the machine completely, remove the bobbin.
Make sure that the bobbin case is securely in its place.
Turn the handwheel and ensure that the bobbin case is not jamming.
Turn the handwheel until the take-up lever is in the highest position.
Raise the presser foot and rethread the machine.
Chaeck the upper tension setting and set it around 5.
ALways make sure that you start sewing, stop sewing and thread the machine with the TAKE-UP LEVER IN THE HIGHEST POSITION.
Jul 11, 2009 | Singer 3820 Mechanical Sewing Machine
Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Jun 30, 2009 | Sewing Machines
Singer Inspiration 4210 Mechanical Sewing Machine Logo
1,617 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
