Question about Xerox Phaser 4500 Printer
Phaser 4510 claims repeated paper jams
Every few pages of printing, my brand new Phaser 4510 printer claims that it has a paper jam and that I should clear it by opening the rear panel. There is never actually a paper jam present… I can sometimes get it to clear and go back to thinking it's ready to print by either turning it off and on a few times, or opening the back cover and fiddling with the latches back there. Is it an oversensitive sensor? Any ideas for how to convince it there isn't a problem?
    Novelist:
  • Xerox Expert
  • 297 Answers
The fuser exit sensor had an updated version for that model (old model has a "bounce" problem). Xerox gives a 1 year warranty..I would get them out to fix it pronto !
It is also helpful to have the error code. Press the i button while the printer has the jam message on the front panel. Use the fault code to locate where the jam actually is. (This will help the technician greatly ! )
Posted on Jan 22, 2009
Xerox Phaser7300dt. After paper jam, the printer keeps printing the same page
That's normal for any printer. It's trying to pick up the printing of the entire document.
If it didn't print the same page again after you clear the jam, you would be missing a page.
Apr 13, 2011 | Xerox Phaser 850DP Thermal Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
It is constantly jamming when we try to do a duplex print
Since duplex doesn't get used a lot, much dust collects in the duplex unit. Remove it and thoroughly clean it by blowing dust off. Look for scraps of paper that might have settled in there.
Jul 14, 2009 | Xerox Phaser 4510/B Laser Printer
RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 850. Unexpected repeat printing
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
Mar 31, 2009 | Xerox Phaser 850DP Thermal Printer
Paper jam notification after printing one page, no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
Printer says paper jam, but no paper is jammed
Check the following information.......
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
or
most of the time for a paper jam, there is a QUEUE of papers waiting to be printed. id take out the usb cable via the back of the computer {the one that connects to the printer} go into the control panel, look for printers, double click on that, find the printer, it should say {working offline} right click that, choose the uninstall/delete opts. turn off the printer. reboot the machine, wait until it boots all the way up. take the printer, turn it on, then plug back in the usb cable to the back of the machine. if it is windows either xp/vista it will auto find the usb cable and install automatically. you can then go back to the control panel, printers and it should be listed in the directory. try to right click go to properties of the printer and do a TEST PRINT, should print out.
Jan 31, 2008 | Xerox Phaser 6110 Laser Printer
MP810 paper jam
I bought a brand new canon with my first pc years ago and it was the first and last ia m afraid, it worked for two...yes two...print jobs, i had it a wee k then it just stopped and said a jam, but it turned out to be the paer sensor. Brand new and they had to swap it. Seems a big fault with these. However, the next one seemed to be ok, but i had occasional cartridge issues. I have never had an ounce of trouble with my lexmark apart from alittle toddler paperjam!!!
Oct 05, 2007 | Canon PIXMA MP810 All-In-One InkJet...
1,626 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
