Question about Toshiba Portege M200 Tablet PC
Message before boot
The following message appears and cant' boot:
"RTC battery is low or CMOS checksum is inconsistent"
Even that I press [F1] as mentioned, to set date/time, nothing happens, what can cause this message?
EUGENE
  • megcie33 Aug 28, 2008
    I tried to buy a new cmos but nobody has one with the wires attached to it. where do i get it? I dont have to solder them on myself do i? i tried to tape them to the battery i got but it didn't work
    Genius:
  • 2,785 Answers
Plz try by changing the cmos battey
Posted on Jul 29, 2008
How to do a factory reset on a Nobis 7.85 tablet, it is blocked
Follow these steps:
1. Press the power button and the home button together or Power button and Volume button together for a while, long enough till the Android boot mode screen appears. Press home button to reach the options under boot mode. Navigate through the options using volume key and select "Wipe Data Factory Reset"option using shortcut menu button. Again navigate to the option "delete- all user data" and select it using shortcut menu button. (Make sure memory card is not inside; otherwise the data on it will be lost). After the data is deleted, a message saying "Data Wipe Complete" appears. Press the shortcut menu button to reboot the tablet again. Now, your tablet is as fresh as a new tablet
Feb 05, 2015 | Tablets & eReaders
Wipe my data partition
you need to boot into recovery mode to wipe the data partition. Doing this will reset the phone's data partition. Doing this will delete all data off the device and return it to the same state it was in when you first powered it on.
  1. completely power off the phone
  2. press and hold the power, volume up, and home buttons until you see the Samsung logo
  3. use volume up/down to scroll and power to select
  4. scroll to and select wipe data/factory reset
  5. select yes on any following prompts
  6. reboot device
If the above process does not work on your device, see alternate methods to boot into recovery mode in the following link.
How to Boot Samsung Galaxy Devices into Download Recovery Mode
Oct 18, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
CMOS Checksum Inconsistent
This usually occures when the CMOS/BIOS battery is nearly flat. Replace the BIOS battery and go into the BIOS setting to set the Date and Time etc.
Aug 31, 2011 | Toshiba Portege 3500 Tablet PC
Cmos reset
I have not specifically worked on this make/model of computer.
Technically, you cannot reset this ... I think what you are asking is how can your modify the settings. Typically one would press F2 or F8 or F11 to enter the setup during the boot process. It may be a different F key, it should flash on the screen when you boot.
You could disconnect the battery back up if you can locate it. ..This will remove any custom setting, but will not let you get back in to change it unless you find the correct F key to press.
On the other hand ... there are no more than 12 F keys. You should be able to find the proper one.
If this doesn't work, you should go to www.fujitsy.com/support for assistance.
Thanks for visiting today.
Jan 31, 2011 | Fujitsu Stylistic ST5112 Tablet PC
I replaced my Toshiba Tecra M4 tablet CMOS battery and I am still getting the error why is this and how do I fix it? I cant get passed the CMOS error when I boot the computer.
When you replace the CMOS battery, you must wait about 10 minutes with the old battery removed, before fitting the new one (if you had a problem with the error message before) - when you fit the new battery, plug the tablet in and don't turn it on - this will give the new battery a chance to power up all of the CMOS on the board and settle down. Then turn it on, wait for the error message about the date and time being wrong, set the time correctly and the problem has gone.
Jan 02, 2011 | Toshiba Tecra M4-S435 Tablet PC
I have a toshiba satellite r15-s822. I am trying to remove the bios password. I removed the rtc battery. Is there another cmos battery on the motherboard? What am i doing wrong?
To reset the BIOS read the information from this link.
In case of your Toshiba Satellite R15-S822 laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery (which is on the motherboard) or the jumper.
Dec 10, 2010 | Toshiba Satellite R15-S822 Tablet PC
Need to get into bios
Hit escape repeatedly while booting. When you get an error message that says hit F1 DO IT. Then you will enter bios.
Jun 19, 2010 | Toshiba Portege 3505 Tablet PC
I cant get into the BIOS from Portege 3500
Keep hitting escape while starting up. Message will say there is an error and hit F1. Hit F1 and you'll enter bios.
Apr 18, 2010 | Toshiba Portege 3505 Tablet PC
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
C110 tablet
This is likely your CMOS battery dying on you and resetting your computer's date. Hitting F2 I belive it is will allow you to access your bios and on the second page you can see your date. It will likely be Jan 1st, 1988. Use your number keys to adjust the date and use your tab key to move between month, day, year, ect.
This is a temporary fix however and you will have to do this often until you have your CMOS battery replaced. I have a Travelmate that has the same problem.
Nov 08, 2007 | Acer TravelMate C110 Tablet PC
Toshiba Portege M200 Tablet PC Logo
367 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
