Question about Sony Playstation 3 (PS3) Console
PS3 Question Hi, my PS3 stopped reading discs. So I took a can of air and spray inside the Blu-Ray Drive with the little red plastic tube that fits on the air canister nozzle. And, well... It got sucked in or something, but it went all the way in and I can't figure it out. Is there anyway to get it out without having to pay almost $200 to have Sony do it?
  • wade_93 Jul 29, 2008
    I tried hitting the eject button but it doesn't sense anything in there so it just beeps 3 times.
    Problem Solver:
  • 4 Answers
Hit the eject button and pull it out
Posted on Jul 29, 2008
Our PS3 60gb, with 4 USB ports is having problems reading the new PS3 games. The old PS2 games still play. When it comes to games like Rachet and Clank or any other new game, it will start then freeze. I...
Hi there, it definitely sounds like the blu ray player. They are relatively simple to fit yourself as long as your warranty has expired. If it is still under warranty just phone Sony and they will replace it.
If you warranty has expired then you can buy a working blu ray drive on ebay for around £60. There is a circuit board that is attached to the blu ray drive, it is extremely important that you keep this as it is paired to your motherboard. Your PS3 will only work with that blu ray circuit board, no others.
To actually replace the drive is pretty easy. On the left hand side of your console there is a warranty sticker covering a little rubber bung. If your system is out of warranty peel back the sticker a little so you can remove the rubber bung. Under this rubber bung there is a small torx head screw, I think a T8 torx but a small flat blade screwdriver will take it out.
After you have removed this screw the whole top of the PS3 slides to the left and comes off. Underneath the PS3 top cover there is another plastic cover with screws all around it. As you are looking from the front of the console there is a marking on the plastic cover that points to one screw that says "S", this is a shorter screw and only goes back in that place. Remove all the screws. Just to the left of the short screw there is a small recess in the plastic casing where you have to push a little black clip back gently while lifting the cover from the back of the PS3. It should all lift forward and come off.
On the right hand side of the PS3 you will now see your blu ray drive. It lifts up but be careful, there is a ribbon cable and power cable attached to it. The ribbon cable is hidden underneath. You have to carefully lift the long black strip that is on the clips where the cable is held. This will release pressure on the ribbon cable and allow you to remove it. You will see the blu ray logic board attached to the back of the drive. Remove this from the drive taking care with a very small connector with a black and red wire, this is the optical sensor wires, remove with care!! Nowafter you have done that you are ready to replace your blu ray :)
Hope this helps and thank you for using FixYa
Aug 29, 2010 | Sony Playstation 3 (PS3) Console
Tip
PS3 stop reading disks? heres how to fix it.
So your shiney black pearl stopped reading discs huh? Now you are wondering if you can fix it because A)You are out of warranty and don't wanna pay almost 200 bucks to have it fixed or B) You are under warranty but don't wanna be without your PS3 for almost a month or longer .... Maybe you casn fix it on your own, if the problem is simple enough.
Sometimes the PS3 won't read discs simply because the lens is dirty, to find out if thats the case insert a game or blu-ray disc ... take careful note of the disc's 'label' as you put it in ... once it doesn't read after 10-15 seconds eject it ... if the disc's label hasn't moved your blu-ray drive's 'motor' is broken. Best bet is to send back to Sony and pay em. Or take the PS3 apart and try to replace the whole blu-ray drive.
If you remove the disc and notice it has moved your lens is probably dirty. This you 'can' fix yourself. First give the PS3 a GOOD cleaning. Vacuum it, blast it with a can of compressed air, vacuum again. Try disc.
Didn't work? Try a lens cleaner kit.
Didn't work? Time to get your hands dirty ... open the PS3 up (at your own risk) and clean the laser manually with pure alcohol and a q-tip. (video tutorials are on youtube.com)
Disc read errors are our main problem. It isn't some full blown epidemic but IS becoming worse by the day. My reasoning for this problem is simple: The PS3 is a dust MAGNET. I'm betting 90% of the disc read errors are cause by dust and dirt and pet hair getting in the machine and making the lens dirty or causing actual failure of the drive motor itself.
I love the PS3 and wish it didn't fail for anyone, especially this month with great titles almost here, but it happens. Happened to me on April 1st and I found out my blu-ray drive motor failed. A dirty lens I woulda fixed on my own. We really need a good blu-ray cleaner kit to come on the market in all major retail stores.
Peace PS3 fans.
on Jan 30, 2010 | Video Game Consoles & Games
The system is not reading any games
Hello there,
The reason your system is not reading any game is because the lens is not working, to fix this, follow the steps below;
  1. Unplug the power cable, video cable and controllers and remove any discs from the disc drive
  2. Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  3. Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  4. Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard
  5. Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  6. Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  7. Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  8. Replace with new laser module, reverse your steps and reassemble the PS3.
Take care
  • Step 2 Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  • Step 3 Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  • Step 4 Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard.
  • Step 5 Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  • Step 6 Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  • Step 7 Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  • Step 8 Replace with new laser module, reverse your steps and reassemble the PS3.
  • Read more: How to Repair a PS3 That Does Not Read a Disc | eHow.com http://www.ehow.com/how_5778475_repair-ps3-not-read-disc.html#ixzz0sQmwqziZ
    Jul 01, 2010 | Sony Playstation 3 (PS3) Console
    PS3 BluRay Drive Issue
    dont change the drive change the laser dhe drives are coded to each ps3 if that dosent work just change the hard drive whit the one that works
    Jan 06, 2010 | Sony Playstation 3 (PS3) Console
    Does not recognize there is a disc in the system whether its a game or movie
    Hi, this is a very common problem with the PS3. Most of the time (at least 90%) its your laser is burned out and needs replaced. But before we assume that, lets try cleaning your laser first and see if that helps. Get a can of compressed air or an air compressor and blow out the DVD drive and see if there was anything on the lens. Then try to put a disc in and see if it plays. Sony has had alot of problems with the Blu-Ray/DVD lenses because of the Blu-Ray lens has to be so close to the disc to read it and the games, Cds, and DVDs are actually thinner and warp a little thus causing them to smack the Blu-Ray lens and eventually causing it to scratch the lens and burn out.
    Aug 17, 2009 | Sony Playstation 3 (PS3) Console
    My ps3 stopped playing ps2 games
    Hi, it sounds like your laser may be dirty or need replaced. First try to run a laser lens cleaner through it. If it won't read the cleaner, then try to blow out the DVD drive with some canned air or with an air compressor. If that dosen't help then your laser is probably burned out and needs replaced. This is a very common problem with the PS2 and PS3 systems. Remember that a PS3 has 2 lasers in it so it might still read Blu-ray discs and not anything else, but the red laser for the DVD,CD,PS1&2 games might be burned out.
    Aug 11, 2009 | Sony Playstation 3 (PS3) Console
    PS3 wont play games but will play DVD, Blue Ray
    You seem to have alot of problems with your console.
    Jun 21, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 won't read disc
    When Blue ray disk is placed into slot it seems like it is going to work and the screen on tv shows the entro for sony but nothing happens. Controls on controller will not function.
    Apr 29, 2009 | Sony Playstation 3 (PS3) Console
    PS3 Blu Ray Drive Not Reading Or Spinning Disc
    Check your cables. Try swapping lasers with a friend. Those are the first things I would try.
    Feb 18, 2009 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    44 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Iron
    Iron
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
