1. Do not connect the webcam to your computer before installing the
drivers. If you accidentally begin installation with the webcam
connected, the Found New Hardware Wizard dialog box appears. Click the
Cancel button.
2. Then download this updated driver pack. It is a
zip file you must unpack to a folder.
http://blog.benjarriola.com/Vibra.zip
3. Click the names of the drivers and applications you want to install on your computer.
4. Follow the instructions on the screen to complete the installation.
You may be asked, after an application is installed, if you want to
restart you computer. Do not restart your computer until all the
drivers and applications are installed.
5. Connect the webcam's USB cable to an available USB port on your computer and wait for Windows to detect the device.
6. When the Found New Hardware Wizard dialog box appears, select
Install the software automatically (Recommended), and then click the
Next button.
7. When a Microsoft warning dialog box appears, ignore the message and click the Continue Anyway button.
8.Installation will complete.
9. Check the image in the Video preview pane of the Vibra Webcam Camera
Configuration dialog box. If it flickers or displays a series of dark
bands, click the Cancel Flicker button.
10. Click the Finish botton, and reboot if necessary.
When you boot up, you can check the Device Manager (Control
Panel > System > Device Manager). Click the plus(+) sign next to the
Imaging Device icon. The entry "Vibra Webcam" should appear.
Done!
Hope this helps :)
Chris (ziraffa)
