SOURCE: the locking mechanism in our
Very often it's simply crumbs in the wrong place.
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
SOURCE: Dualit 20247 2-slice crumb tray needed
At the Dualit Service Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
SOURCE: received 2 slice toaster (kitchenaid)
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
