Question about Toshiba e-Studio 350 Copier
How do I add developer to a E-Studio 350
Sometimes it prints light on part of the paper. I think it is the developer. also how do I find the waste toner so I can empty that. I'm in Redondo Beach CA and could use a tech.
  • Anonymous Apr 24, 2009
    I have light areas on both prints and copies. Looking for a tech that serves the Norther Virginia area
  • nadeem030498 May 25, 2009
    very light printing some times some parts of the pictures ony
  • 148 Answers
The developer should be change by a tech. You have to dump the old and replace with new and then set the developer calibration. Waste toner is right in front, a black container that you remove, dump, then put back in place, try to do that each time you add toner so that it never fills all the way full. I do service your area if you need help. Email me at
Hope that helps...
Posted on Aug 02, 2008
My thoshiba e-studio 352 giving an error "latch the developer unit". Please help to resolve this issue. Thanks Roy Robinson
I think the cable is not connected properly on the developer unit...Open front cover, take out the waste toner box, and u will see the connector.
Oct 02, 2013 | Toshiba e-Studio 350 Copier
I have toshiba e studio 163 spanner key is on, the mashine is not working . How cat I reset the spanner key.
I think the paper has moved half- way and may get jammed. Switch off the printer and try again. Remove if the paper is jammed. Sometimes, the frequent electrical power fluctuations also is a reason for it. I do have this problem in toshiba e studio 166 printer. After sometime, it gets alright by itself. The reason is not exactly known to me. Mostly the problem is coupled with paper jam.
Sep 03, 2013 | Toshiba e-Studio 350 Copier
My toshiba e studio 350 machine toner is very could adjest devoloper and toner ratio please help.
05 turn on copier hold for 5 sec will go to test mode 200 print will start developer calabration going down in numbers adds less toner go down about 50 in numbers so it wiil stop adding then press set this is done all on touch screen except for 05 and 200 use keypad
Feb 07, 2013 | Toshiba e-Studio 350 Copier
Toshiba studio drivers
you need to change the developer if it makes over 100000 paper
May 02, 2011 | Toshiba e-Studio 350 Copier
Cof32, blank copy on printing and copying bizhub c350
C0F32 is e developer problem,Imaging Unit ATDC (automatic toner density control) failure.
Try to add some toner and adjust the developer.
Enter service mode and adjust with F8
Apr 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Print a part of paper
I will recommend to do a negative post copy. Then check whether solid black or not. If not solid or blur, then the developer material might be dirty or not enough where u need to replace. If only certain area, such as top or bottom part not solid or blur, it might be caused by the roll guide also where u need to replace it.
To replace developer is very simple, take out the waste toner box, unplug the connector on the developer unit, loose one screw, and u can take out the unit. On the unit, take out the 2 screws, and u can open the cover.
May 25, 2009 | Toshiba e-Studio 350 Copier
Error 270940 for Estudio 350
The A3 paper will not pass through the copier when the cassete is full. Copier states "Add Paper". When you push the A3 tray in you can hear a winding sound and then when you startt to copy it asks you to add paper.
Apr 16, 2009 | Toshiba e-Studio 350 Copier
Toshiba estudio 35
What is the copy count on the machine?
Toshiba copiers have service intervals to replace the drum, cleanerblade, corona wires and developer material.
That could resolve your printing problem.
May 09, 2008 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 350 Copier Logo
297 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
