Question about Akai PT4298HD Rear Projection Television
I need to fix the power supply
Tv won't turn on
  • fjzepeda Jul 29, 2008
    Ineed to fix the power supply I need to know how find the capacitors on the power board
    President:
  • 2,267 Answers
Where can I send you the schematic diagram?
Posted on Aug 01, 2008
  • 4,234 Answers
Are you sure that the power supply is the problem? These sets have protection circuits built in that shutdown the power if a problem is detected. What are the symptoms of the problem? Perhaps we can walk you through the repair. Typically Akai schematics are not available outside of the repair centers.
Dan
  • 813 Answers
  • 13,433 Answers
Here you can see what capacitors look like'
http://nucth.physics.wisc.edu/personnel/yamac/Phys102/capasitors2.jpg
those 4 there.
then 6 below
Posted on Jul 29, 2008
    Guru:
  • 1,894 Answers
Please try a hard reset to turn on the TV
  • dewan nafees ahmed Jul 29, 2008
    leave the unit plugged off from the wall power for one night
    and then again turn ON the unit
    if it comes ON then problem may be a minor one.
    else there may be any damaged capacitors in your power board.
    you will have top replace them as soon as possible before they damage more and start leaking in your power board causing a major damage.
    thank you
    you can find few big capacitors in the power board.
    you need to just replace them
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
Hitachi tv turns on then sometimes it won't
The clue is does the power light come on or not, several of the older ones had a problem with a relay in the power supply, unplugging set one or more times would allow set on.
Sep 02, 2012 | Televison & Video
Tv goes off then comes back.
Sounds like you might have a cold solder or bad connection at the power supply. Don't fool with this yourself. TV's today are very delicate and you need to take it to a professional. It probably won't cost you much. Let him take a look at it, give you a price for repairs, then let him fix it for you.
Jun 14, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV clicks but won't come on .
Check for bad capacitors in the power supply section. Sites like www.TvRepairKits.com have power supply repair kits if needed,
Mar 22, 2012 | LG 52SX4D 52" HDTV
My toshiba RC-3910 tv turns on but 10 mins later it turns off and it wont turn back on why
hello!
it seems, like the problem of your TV is the power supply module, particularly 12v power supply I.C. chip.STRW6735 or similar. I've replaced few lately with similar problem TV. It might have a few bad electrolytic capacitors on the board, as well. Solution: if you are possess electronics technician skills and have all the necessary equipment and parts , you may do the job yourself. Otherwise, look for replacement power supply board, preferably at used boards distributors(shopjimmy.com or similar). I won't recommend to buy used on e-bay, unless it has been rebuilt. Or, remove the board and take it to local TV repair shop for rebuilding. This way you may save a few bucks.
Good luck,
Alex.
Mar 06, 2012 | Televison & Video
The tv wont power on at all
Your TV Won't Turn On
If your TV won't turn on, you should check the power cord. Make sure that it is securely in the wall plug. Sometimes the power cord has burned out and needs to be replaced. You may also want to check the batteries in the remote to make sure that they are working properly. If otherwise
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if otherwise, Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help to solve the problem.....
Jul 07, 2011 | HP Pavilion MD5020N 50" DLP HDTV
I have RED verticle lines all the way across the screen fro top to bottom 10 minutes after I turn my Panasonic PT-52LCX65 TV on. Is there a solution?
Hello
Check and replace the main filter capacitor in the power supply section. Replace all of them in the secondary section of the power supply too. The problem is due to insufficant smoothing and regulatio fo the power supply section. If main smoothing capacitor gets value deveoped, it won't supply enough voltage to the switching section, and switching section also will go inefficient. Replace all of them. It won't cost not much. OK.
Jun 22, 2011 | Panasonic PT-52LCX65 44" HDTV
The red light keeps blinking and tv won't turn the fan won't come on either
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help out in solving the problem....
Jun 19, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
RCA P61927 61 in. Rear Projection Television
get a tv repairman out to make sure of the problem, it might be xomething simpler he can fix but it sounds like the convergence board is out
Jun 21, 2008 | RCA P61927 61" Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
88 people viewed this question
Top Akai Televison & Video Experts
Dave Naylor
Dave Naylor
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
