Question about Cameras
I need a 5V camera adapter to my digital camera, where can I find one?
    Master:
  • 623 Answers
Try your local electronics shop or camera shops
Posted on Jul 29, 2008
Where can i buy a switching adapter for our philips 10 in. digital frame? model DSA 12 PFA-05 FUS 050200 input 100-240 V output +5V
if you mean a switching adapter for your phillips 10 in. radio shack has an adapter set with multiple plugs and voltage and amps here is a link to one on amazon http://www.amazon.com/5V-1-2A-Universal-Power-Supply/dp/B001KU44HE that looking up your model should work. also walmart and best buy carry adapters with multiple plugs as well hope this helps let me know
Mar 14, 2011 | Philips Cameras
12v charger use in kodak m863 help
This camera is only compatible with a 5V adapter/charger and it should charge via the USB cable.
In order to order your 5V adapter please follow this link:
http://store.kodak.com/store/ekconsus/en_US/AddItemRefID/pageType.product/externalRefID.EKN034940#accessories
Dec 19, 2009 | Kodak EasyShare M863 Digital Camera
I'm looking for a USB connector for my Fuji DX-7.
Your camera is intended for serial connection.
You can get RS-232 to USB adapters, but I'm pretty sure that they wont work with your camera. DX-7 was originally equipped with 5V Smartmedia cards. Newer (!) type cards are 3,3V. You can get a card-reader for 3,3V cards but not for 5V cards.
You can tell the difference between 5V and 3,3V by the missing corner of the card. Seen from the "golden side" 3,3V cards are missing upper right corner, while 5V cards are missing upper left corner.
I don't remember if DX-7 could use both types.
Dec 07, 2009 | Fuji DX-7 Digital Camera
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
Nov 24, 2008 | Kodak EasyShare V610 Digital Camera
Digital camera
Hey CARLOS,
You could try getting the correct charger from the manufacturer, and/or a new battery. If this doesn't work you should probably have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 21, 2008 | Cameras
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
