Question about Canon CanoScan N640P Flatbed Scanner
Re : CanoScan N640P/Lexmark Printing Problem.
Im using Windows XP and when I print anything without scanning my Lexmark printer works perfectly but when I scan something with my CanoScan N640P the whole back ground prints black instead of remaining white.
  • mason45 Jul 29, 2008
    Thank you for your reply the backing colour is flat white. cheers.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Lift up on the scanner cover and tell me what color the backing for the cover is?
    This would be the part of the cover that sits on the scanner glass when scanning.
  • Canon Master
  • 2,794 Answers
There could be a setting in your scanner drivers to fix that. It would be under background settings.
The other thing you can do is preview the document first and select the area you want to scan. Then press the scan button again. That way the black background that isn't needed will not print.
Posted on Jul 29, 2008
Looking for windows 7 driver for canascan n640p
Download the CanonCraft CS-P 3.8 (if you losse your cd installer) After installing your CanonCraft CS-P 3.8 (the software from your canon scanner)Try this : Open your CanonCraft CS-P 3.8 than go to setting (klik setting button) --> preferences --> loss the ColorGear Color Matching checklist -->klik Change Profile and chose SMPT-C and klik ok. Hope this work (i've try this on win7 and win8 and work well)
Feb 27, 2013 | Canon CanoScan N640P Flatbed Scanner
How can I get Canon CanoScan N640P ex Flatbed Scanner to work in Windows 7?
Hi Nubi ,
There is no direct solution since Canon doesn't support your device under Windows 7 .
You can install a virtual version of Xp on your machine with http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html or via Microsoft if you are using Ultimate or Professional .
Otherwise , you will need to purchase a replacement device compatible with Windows 7 .
Best regards ,
fanaudi .
Aug 27, 2011 | Canon CanoScan N640P Flatbed Scanner
I hab Bought one USB-to-Parallel connector to connect my Canon Scanner .But I cannot able to scan .It displays Error Code 0*00070800. No scanners detected My Scanner mobel No :Canon N640P ex
I have many years of experince repairing Canon scanners so here is my suggestion.
First off I would go back to USB its faster then a parallel cable for scanning purposes. Second if your computer is a very old one then just get a usb card and install it in to your computer. Also make sure you have the latest drivers for the operating system your running. The drivers are free on Canons website. Just google Canon Canoscan N640P drivers it should take you directly to Canon's website also I would download capture perfect its free also an will function perfectly with your scanner.
When you install the newest drivers make sure your scanner is disconnected from your computer. Once the drivers are installed then attach the USB cable to your computer. You should get a message saying new drivers are being installed then reboot your computer and you should be good to go with whatever you want to scan.
I hope this helps you out.
Mar 31, 2011 | Canon CanoScan N640P Flatbed Scanner
Error code 0x24050010 Canon scan N640P in windows 7. please please help me...
What you need to do is run the driver setup in windows XP compatibility mode.
Right click on the setup icon, select properties, compatibilities tab then select Windows XP SP3 (or some older version of Windows.
Then left click on the "Change settings for all users" button and from the new window select again XP service pack 3 compatibility and check the "Run this program as an administrator". Click OK and then run the setup application.
It worked for me on Windows 7 ultimate.
Sep 16, 2010 | Canon CanoScan N640P Flatbed Scanner
Convert canon canoscan N640P EX to use usb
please the old scaner programmi is unstoll and you go a run and add a scaner progremme cd instolldrriver orignal and start the scaner is on
just you used the window xp if fouto didate and give a usb cable and use a scaner
Sep 22, 2009 | Canon CanoScan N640P ex Flatbed Scanner
Driver for Canoscan N640P for windows vista home premium 64 bits
You may be out of luck; here is a version for XP/NT that you could try to force-feed to see if it will work;
# Model: CanoScan N340P
# Size: 3.73 Mb
# Version: 3.8.2
# Date added: 09-Jan-2007, 10:36
# Manufacturer: Canon
# Device type: Scanner
# Operation system: Windows 98/ME/2000/XP
# MD5: 582d83ae6df3ea4bd0a3465a2750c020
http://www.nodevice.com/driver/CanoScan_N340P/get36948.html
You can download the driver from this IP address (72.56.181.99) within 24 hours. After 24 hours you will have to use the driver request form once again. Thank you for understanding.
Dec 15, 2008 | Canon CanoScan N340P Flatbed Scanner
After preview with correct colour, print comes up pale colours.
Have you confirmed that the scan you are trying to print is good?
Dec 13, 2008 | Canon CanoScan N640P Flatbed Scanner
No scanner detected on N640P ex scanner
I was recently faced with this same problem, with non detection of the scanner N640P ex flatbed. It has a card for the parallel port connection and was installed by a computer repairer to save me time. He said it worked, but when I got it home, it failed, even with the new driver added.
Here is what I did.
Check the ports in which are used for the scanner, mine was found to be LPT2, I changed that to LPT1.
(Be prepared to reverse these 2 if necessary).
I did a reboot and turned on the scanner and it showed it was there but refused to bring up the Toolbox to scan anything.
Next step, go the Microsoft and pick up this "Restore parVdm" this belongs in Windows System 32 and aids in the recognition of not only your scanner but other vital peripherals.
Its a microsoft fail when the parVdm does not recognise something.
I installed that as it comes down in .rar file, and rebooted, and all is working exceptionally well.
Will this work with any other OS? I have no idea. This worked for me on XP SP3 but parVdm also exists in Windows 7, 8 and Vista.
ParVdm Windows XP Service batcmd com
Aug 08, 2008 | Canon CanoScan N640P Flatbed Scanner
Printing - using the 'copy' mode of the scanner
This suggests the the 'copy' element of the software is not VISTA compatible. In VISTA help in my computer - check out the 'compatibility' options and select an operating system that the copy function did work under
Aug 31, 2007 | Canon CanoScan N640P Flatbed Scanner
Canon CanoScan N640P Flatbed Scanner Logo
97 people viewed this question
old marine
old marine
