Question about MGE Galaxy 3000 UPS System
MGE Galaxy 3000 UPS shows charger internal fault .
Hello!!
My MGE Galaxy 3000 UPS 15KVA shows charger internal fault .
I check the charger /rectifier voltage is just 64Vdc at the battery breaker.
May I know this UPS need battery to start -up?
Thanks!!
  • 1 more comment
  • wkyong Jul 29, 2008
    Hello!!
    Thanks!!
  • majid Oct 22, 2012
    hello!!! yes , it's need battery to start-up.
  • Anonymous Mar 20, 2014
    software
Mge galaxy 3000 battery circuit breaker shut off when normal power shut off too.plz help !!!!!!
Posted on Jul 07, 2012
Rectifier internal fault
check scr,check diodes,check driver cards
Aug 26, 2015 | MGE Galaxy 3000 UPS System
Ups mge galaxy 3000 G3K
If you cannot do a reset of the internal fuse system and get it operational, then check the internal battery for continuity. If they all fail, then the AC/DC transformer has blowen.
Mar 15, 2014 | MGE UPS Galaxy 3000 UPS System
Hello, our MGE GALAXY 3000 20kva, front panel display is frosen. UPS still operates but not able to use any buttons to see ups status. Also alarm states "internal communication fault". Would appreciate...
you need an MGE expert engineer to check on the internal components, maybe the display by itself it dead can be replaced while UPS is on no problem. if you want to switch off the UPS you go for force shutdown but I cannot guarantee will restart if you do not fix the fault.
Aug 09, 2013 | MGE Galaxy 3000 UPS System
Galaxy 3000 30kVA showns battery charge fault.beacause battery?
UPS battery must be tested individually before you can decide it is a battery problem or if charging fault can cause by defective rectifier/charger board.
Sep 09, 2011 | MGE Galaxy 3000 UPS System
Hello I have a problem on MGE Calaxy 3000 20KVA UPS. I change the batteries with new batteries when i put it on, the battery status deos not come just give me xxx . before has this erorr "UPS...
The Galaxy 3000 uses a software which has all the data of the batteries used for the commissioning. However if the battery replaced are not of the same specification then the XXX would appear, meaning the software cannot match the specifications. Please try for first principle, check the ac in, check the rectifier and so on. Across the battery circuit breaker (in off position) compare the battery voltage and the charging voltage. This would give you an indication if the charger is working.
Apr 08, 2011 | MGE UPS Galaxy 3000 UPS System
Mge galaxy 3000 how to reset battery expire alarm after battery change
Unfortunately the reset is only possible with MGE software (Softunor).
Jan 24, 2011 | MGE UPS Galaxy 3000 UPS System
Hello Ive got cooling fault on my galaxy 3000 can u help
try to check the fluid in the cooling system, if it's full. then try to check the sensor on the cooling cap, or maybe change the sensor. Hope this help.
ps: cooling liquid is not water ( buy it from mge, i forgot what's the name )
Sep 04, 2010 | MGE UPS Galaxy 3000 UPS System
I have an MGE Galaxy 3000 15KVA which i replaced the batteries. The problem is that the fault alarm and the fault LED lights are not going off despite shutting down the UPS. I even shut the UPS on the...
This is Easy,
MGE software is exclusive to them, they do this so that in the event the UPS needs any work you have to use them for remedial work, the problem is because they hold the monopoly they charge through the roof for parts and labour. you will need a factory trained engineer to turn up with a laptop to switch off the "Maintenance Alarms" I have an engineer that has the Software and availabilty to parts and we are much cheaper than MGE direct.
if you need any UPS help contact Glenn Prince @ Adept Power Solutions Ltd 01264 326726 or go to website www.adeptpower.co.uk
Jun 09, 2009 | MGE Galaxy 3000 UPS System
Rectifire internal fault
the mge galaxy 3000 ups dont start atall when switch to normal position
Apr 06, 2009 | MGE Galaxy 3000 UPS System
Computers & Internet Logo
2,202 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
