Hi and welcome to FixYa
Insert the installation disc into your CD or DVD drive.
Restart your computer.
When your computer is restarting, you will be prompted to "Press any key to boot from CD". Simply press any button on your keyboard when you see this message. If you do not see this message when you restart your computer, you may need to reset your boot disk sequence. *
*To reset the boot sequence, go into BIOS mode. To do this, restart your computer and while restarting press the F1, F2, F10, or maybe the delete key (your computer screen will say "To enter setup press xxx". You only have a few seconds to press the correct key, so if you miss it you will need to restart your computer and try again. Once you have successfully entered the BIOS mode, look for your boot sequence options. Set the CD ROM drive to be the 1st in the boot sequence. Save your changes and exit.
The CD will load a blue screen, then after a few minutes will ask you to press Enter to set up Windows.
You will then be prompted to select where to install Windows. There will be a box on the lower half of your screen that will either show "Unpartitioned space xxxMB" or will have "Partitioned space xxxMB". Highlight which partition you wish to format (typically it will be the unpartitioned space or the space with the largest partition by most megabytes). Hit Enter after selecting the space to partition.
The next step is to choose which file system to format the drive with. The NTFS option will be the fastest option. For most formatting purposes, choose the option that ends in "Quick". Press Enter when done.
The computer will then begin the formatting process. This process may take a while depending on the size of the hard drive you are formatting and the speed of hard drive.
As soon as the drive has been formatted, the operating system files will be copied to the hard drive and the operating system will start installing.
Hope this information was helpful
Sincerely,
aDynamite.
Reinstall the OS and choose clean install.
Resetting
a Dell Inspiron 1011 to the factory settings allows the user to restore the
Dell Inspiron to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1:
Before reset any Dell Inspiron 1011 laptop, backup your all important data
and programs, otherwise you may lose it. It is recommended to use an
external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Inspiron reset process...
This
process will erase all your previous changes that have been made to the
Dell Inspiron 1011 laptop and reset the configuration settings to factory
setting.
Feel free to get technical assistance for all models of Dell laptop at http://www.vtechsquad.com/dell-support/
