SOURCE: Transferring video footage from a Canon MV830i to a laptop
Here's the driver..Connect the camcoder to computer and then install the driver..you can find it here..
http://software.canon-europe.com/products/0010209.asp
Also you might want to buy a firewire card if you want to transfer a footage without any hickups..
SOURCE: Transfer to Computer?
yes all you need is intervideo windvd software...or you can use movie maker from window xp sp2
SOURCE: Mini DV tapes transfer to computer
wow, i have the same exact problem. im using a canon too. and i dont have an installation CD or anything, because i baught my camera at a pawn shop. the only thing i can think of is that i might be using the wrong type of fire wire cord? do i need to use a DV fire wire cord? i have no clue.
SOURCE: Connecting my Sony Camcorder CCD-TRV 108 to my computer
To do this you will need a firewire cable 4 to 6 pin, here a link:
http://www.amazon.com/Belkin®-Firewire-Cable-4-Pin-6-Pin/dp/B0016W3L3O/ref=sr_1_3?ie=UTF8&s=office-products&qid=1226166429&sr=8-3
you'll plug the 4 pin connector, that's the smaller one, into the DV port on the camera, then you'll plug the 6 pin into the computer's firewire port.
now open WMM, iMovie, Adobe Premire, whatever you are editing with:
imove: got to capture> video from camera, in the new one there should be a little button with a camera, just click that
WMM: Click record> from camera, then put your camera in playback mode, and hit record on WMM, start playing and BAM. same prcess for recording applies to pretty much all of them.
SOURCE: transferring video from tape to PC
Hi. I do know how to do that. You need some software that's capable of controlling the camera such as Adobe Premiere, Final Cut, or something like that. I believe Microsoft Movie Maker will do it and so will Roxio Media Creator which is the package they sell that burns CDs and DVDs as well. It's a whole media center.
The camera has the capability of being controlled through the firewire port on the front. You get a cable for the firewire port on the camera (firewire mini 4 pin) that goes to the computer (firewire 4 pin standard size). If you have an older computer with no firewire and it does have a PCMCIA card slot sometimes called a PC slot, or express card slot ... you can buy cards that will give it firewire ports.
You MUST have firewire to do this. The newer machines like the Acer Aspire One or any of the netbooks don't have any way to add firewire although the CPU is fast enough for video work. I capture on my old computer with firewire, and save the video to an external hard drive and edit on the netbook. Anyhow, I'm getting sidetracked!
Open your editing program and have it do a movie capture. The capture window will have buttons that look like the ones on the camera for fast forward, reverse, play, stop, etc. plus a couple for single frame reverse and forward which is useful for editing. It will also have a record button on the software. Play the tape and just as you start it, hit record. It should capture and you'll see a little data window on some software showing the frames captured and dropped during capture. That's about all there is to it. Editing is a bit trickier and I'm still learning alot of it. You can get older copies of Premiere online from a number of different sites. It's my personal favorite. It does more ... but the movie making software Microsoft provides with Windows XP and above will perform the capture perfectly well. Good luck with it.
If you have trouble, I'll be happy to get online in a chat session and talk you through it if that would help. I'm on AOL and my email is [email protected].
Lynn in New Orleans
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
