Time machine uses a special type of file called a sparsebundle to store backups on the drive. If it was working before, perhaps something has happened that is not allowing it to connect with the same permissions.
1. Use the Finder to navigate to the external drive you use for TimeMachine.
2. Select the filename that ends in 'sparsebundle'.
3. Click Command+I to bring up information on the file.
4. Under Sharing & Permissions ensure that either your username or 'everyone' has read/write access to the file.
If this is your first time using this external drive with the mac then go ahead and format it with Disk Utility and it should work after.
It sounds like your WD drive is formated in NTFS. For Time Machine to work the disk should be formated in FAT.
Actually, the drive should be formatted for HFS , Journaled, for Mac OS X. If it's an intel iMac then it should be GUID partition type; if it's the older, pre-2006, PowerPC type then it should be Apple Partition Format. Either way, keep journaling turned on.
FAT should only be used if you need to use that external hard drive with both Win and Mac. Also FAT32 only supports up to 32GB with 4GB chunks. It's best to use HFS if possible with TimeMachine.
