Question about Gateway Computers & Internet
This computer 5310s ser#0035081700 has all of asuden when sets idle it shuts down on its own also put it on stand byit shuts down and when turned back on it comes up on windows log just like it had been on stand by Also at times it is running it burst out with in the sound system just replaced hard that got scrambled messed up trying to make a large down from windowsup date it seemed to have started on down load desk top search but removed it sameoldsame no improvement
    Problem Solver:
  • 26 Answers
Get to the control panel and get to the power options and configure it to yor specifications concerning, the power button, standby and shutdown options, thnx
Posted on Jul 29, 2008
Bike shuts off when putting it into gear
Is your idle RPM set too low? Consult a manual and see what the RPM should be.
Jun 02, 2014 | 2003 Yamaha Road Star Silverado
I have a 1990 S-15 with 4.3 motor idles high when you start, idles down , set and idle for a while it starts idling up and down.any idea's?
Could be a faulty idle air control valve.
The computer controls idle speed by regulating how much air enters the throttle body thru the valve.
You could unplug the valve when the idle speed is close to normal, then shut the engine off and restart to see if the idle speed is still in the same place. Unplugging the valve will also set a trouble code and turn the warning light on.
Mar 07, 2013 | Chevrolet Cars & Trucks
When I leave my computer for more than 5 minutes, the monitor turns black and I am unable to access my data. I have to use the power button to shut down and start all over again.
Just change the power settings to never turn your monitor off or never put your pc to sleep when idle.
For Windows 7:
Click on Start.
Go to Control Panel.
Go to Power Options.
Click on Change Plan Settings.
Make sure both Turn off the display and Put the computer to sleep is set to never.
Click on Save Changes.
Restart your pc.
The steps should be similar for Windows Vista and Windows XP.
Jul 24, 2011 | Gateway DX482201 (PTGA002002) PC Desktop
My 1985 maxim on start up and shifting from N to 1st shuts off...Iwas told it could be the swich down below close to the stand?
Most motorcycles have a side stand safety switch. If you forget to put your side stand up and put the motorcycle in gear it is designed to turn the engine off . If you put the side stand up before putting the bike in gear , it will remain running. This is so you do not drive down the road with your side stand down, take a left turn, and crash your motorcycle.
Jan 18, 2011 | 1985 Yamaha XJ 700 X Maxim
I have a 2005 Yamaha 650cc v-star bike custom. My bikenturns on fine and engine sounds good. Drove my bike for 10 minuets then when I turned it back on and shift to first gear the bike shuts off. I...
Is your side stand down when you shift it into gear? If you have a side stand safety switch your motor cycle is designed to shut down if you put it in gear with out raising the side stand. It is set up that way so you wont be able to drive down the road with your side stand down , take a left turn, and crash your bike.
Jan 15, 2011 | 2007 Yamaha V Star Custom
Notebook keeps shutting down
there are numerous cases why the computer keeps shutting down. One is the pc is slow to react, the other is when the pc is in idle mode, it did not respond accordingly to its idle time to come back to its original settings. These are just the samples.
To solve this problem, kindly turn off the computer and remove the battery and cables to it. Then using your forefinger, press & hold the power button in between 8-12 secs. Then reinsert the cables and battery to it. Turn on the pc and let your computer be idle in 30 mins. If in 30 mins your pc will shut down, that means there is trouble on your memory module inside your laptop. The RAM (Random Access Memory) keeps your computer in safe and running condition for it is avoiding the pc to automatically shutdown. That is the time to consult ASUS about this issue...
Sep 02, 2010 | ASUS Eee PC 1000H Laptop
My computer shuts down for no reason if left idle for 10 minutes
the computer might be set to go into stand by or hibernation after 10 minutes of not being used. check the power settings in start -> control panel -> power. (will probably have a different name)
another cause might be overheating due to dust in the fans - blocking the airflow.
Aug 07, 2010 | ZT Group CISNET A7022 PC Desktop
Toro snowblower///// tecumseh# on motor is H35-45598R SER 5283B
Usually that is a sign of the carb not being adjusted right. Run it at full throttle and adjust the main mixture needle (usually on the bottom) until it runs the smoothest. Set it in the middle of the range where it runs smooth. Then set it down to idle and adjust the idle mixture until it runs smooth at idle. Accelerate it rapidly and if it bogs or hesitates turn the idle mixture a little leaner (clockwise) and try again until it works right. That should get you very close. Try tweaking it a bit from there. as the microscopic specks clean out of it, it may need more adjusting.
Nov 25, 2009 | Garden
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Stand by
Standby does not turn off the computer. It reduces power consumption but does not turn the CPU off or the power supply. Because the cpu is still on the cooling fan stays on to cool it. If you want it to turn the fan off or be silent I suggest using hibernate or shutting it down completely.
Feb 01, 2009 | E-Machines (308714) Motherboard
Computers & Internet Logo
71 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
