Question about Sony PlayStation Portable (PSP) Console
WON'T RECHARGE When we plug in the psp to charge, the yellow light goes on. After about 3 minutes the light goes out. The PSP will turn on for about 2 seconds and then it goes dead. I just bought a new battery and put it in.
  • 135 Answers
Have you tried using the battery on another PSP? Prolly, the battery is a defective one?
Posted on Jul 29, 2008
PSP Orange light when charging but battery wont charge
Your Battery may have developed dead cells and is no longer capable of charging.
Replace battery with new one
Jun 28, 2013 | Sony PlayStation Portable (PSP) Console
How do i charge my psp battery
Plug the charger into the wall. Plug the other end into the spot on the PSP with the yellow outline. Check for an orange light. If it's on, let it charge until the light turns off. It it's not on check connection. If it's still no charging, take out the battery and put it back in. If it's still not charging remove the battery and try to turn it on. If it will no start, your PSP is bricked.
Sep 30, 2011 | Sony PSP-3000 Silver Console
I have just gotten my psp and i started using yesterday. i only played for about ten minutes, then the game just cutt off. The green light was blinking all the time and i charged it but it still will not...
If you are playing games from custom firmware then follow these steps:-
1) take out your psp battery
2)put on charge direct from charger(make sure the battery is not in psp)
3)turn on psp holding right trigger to move on psp recovery menu.
4)reset all flash settings(it's somewhere in advanced tab)
5)after resetting fullt turn off psp and put psp battery in and turn on here you go.
Jul 26, 2011 | Sony PlayStation Portable (PSP) Console
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
My psp wont charge
The psp isn't made to charge from usb by default, if you see that small yellow plug in on the either the side or the bottom, you should have a ac adaptor that came with it to plug in there.
Jun 14, 2010 | Sony PlayStation Portable (PSP) Slim...
PSP cannot turn on
keeping Lithium ion batteries(found in ur psp) idle for such a long time without charging may discharge them compleatly and even if you try to charge them they will not function. this seems to be a problem with your battries not ur PSP. try to get it replaced from the dealer you bought the PSP from. hope this solves your problem.. :D
Aug 03, 2009 | Sony PlayStation Portable (PSP) Console
Power Problem with my psp
Make sure the plug is all the way in the socket, and make sure it's plugged into an outlet. If those are bouth done. Are you sure it only charges for the 3 minutes? maybe it's full by the time th elight goes off. Uhhh I'd say it's probably something wrong with either the things connecting the battery to the PSP or, the female end of the power connector. Damn females always messing things up.
Apr 28, 2009 | Sony PlayStation Portable (PSP) Console
Psp dont charge
i think its one of 3 things
1. the internal power connector
2. part abxy and power switch circuit board
3. bad battery
Feb 03, 2009 | Sony PlayStation Portable (PSP) Console
My psp wont turn on... i dont even know if its charging...i dont know anything about the psp. my psp didnt come with instuctions!HELP!!!
the way 2 know if tis charging is wen u plug in ur charger 2 ur psp on da right a orange light should appear and stay ther eas long as its charging . wen it goes away it should be blank. if this doesnt happen on urs i dont know why. it should have come wiv a anual in ur psp box unless u have bought a used 1 from someone in dat case dey mite have not given 2 u for whatever reason. i hope dis helped=)
Jan 14, 2009 | Sony PlayStation Portable (PSP) Console
PSP CHARGING PROBLEMS
The way to properly break in a lithium Ion battery is to run it dead before you recharge it. Then fully recharge it and run it until it's dead again. Do this about 3-5 times and then the battery is properly broken in. If you charge it before it dies on a new battery you can build what they call a "memory" where the battery thinks it's fully charged however it's only maybe half charged and you will lose alot of life out of your battery. So make sure you properly break it in.
Feb 02, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
67 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
