Question about Kenwood Audio Players & Recorders
Kenwood UD700 home stereo. No sound from speakers from turntable, tape decks or CD
  • 979 Answers
Be sure that the "tape mon" in not selected...accordianman
Posted on Jul 29, 2008
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
The word "protect" appears on my screen and shuts my unit off; what should I do.
Sounds like you have either a speaker wire exposed and/or crossed. Or speakers that are capable of too much wattage/ohms resistance for the receiver to match.
Jun 21, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Reorded tapes only play out one speaker
check your cables to the units channel that doesn't work, for breaks. Does the cassette player play back a pre-recorded tape okay? if it doesn't there might be a internal fault.
Check the wires to the tape head to see if one is off.
Jun 06, 2009 | Kenwood CT-201 Cassette Player Single Dual...
Rca 5 disk changer stereo model # rs 2640b
Unit may have defective amp or blown speakers. Have serviced
Aug 09, 2008 | RCA RS2620 Single Cassette Deck
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
Feb 03, 2008 | Audio Players & Recorders
Record player works but no sound from speakers
I've had this happen before, and it is caused by your ground wire not being hooked up. Depending on the type and age of turntable, it will have an additional wire (the ground), that needs to be hooked up to either a screw or some sort of opening similar to your speaker wire hookup. That should take care of the problem. If you don't have a ground wire coming out of your turntable, I don't know how to help, other than figure out how to ground the turntable.
Sep 29, 2007 | Audio Players & Recorders
131 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
