Question about RCA D52W19 52" Rear Projection Television
3 colors the tv is showing three colors in the image and i dont know what to do to fix it??
  • 4,234 Answers
This is a problem with the convergence circuit and can be repaired at home if you can solder. Let me know if you wish to do this and I'll rpovide more details.
Dan
Posted on Jul 29, 2008
  • 1,586 Answers
When my JVC did this, I had to replace all three electron guns. Thankfully it was under warranty, as they were around $300 each.
The tv image is showing in three colors....Almost ghost like but in three colors. I checked my connections and tried my blue ray player and the image is still messed up....I did press the magic focus...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Tv screen
Ur tv have convergence problems,it dead.U must know how to solders?U must repalced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-$350 for parts and labors.
Apr 23, 2010 | RCA HD52W59 HDTV Projection Television
My projection tv is showing a triple image and i don't know how to fix it?
Go to menu then setup if you do not see convergence listed in menu then you have blow Fuse FL231. Located next to FBT flyback transfomer on right side there is 3 fuses in a roll they will look like small rectrangler caps but are Fuses.06 amp
Apr 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Converging problem
This is a rear projection TV that uses three color "guns" in a cathode ray tube . They are no longer converging at the screen. The convergence problem is usually a sign of something else gone wrong with the high voltage.
Do NOT attempt to open this set yourself. This type of TV can have LETHAL voltages inside for WEEKS after it is unplugged. The repair and convergence calibration will require a qualified service technician.
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
My sony KP-51WS500 is having ghosting problems with kind of 3D image with the three colors showing seperate image lines. How do I fix this and what is the cost.
Shop cost u about $300.Ur convergence is dead,U know how to solders.?Buy a convergence kit to repair.Tries websites. Tv repair World.com,Tv repair Kits.
Dec 12, 2009 | Sony KP-51WS500 51" Rear Projection...
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
IC replacement didn't solve convergence problem for 57HX83
the convergence in any tv is as this analogy:
a pencil, a hand and the brain.
i would say the pencil is the joke and the ic (convergence amplifier) together.
the hand is a copy of a program that always do the same.
and the brain has an original program plus the eeprom to help him.
and what ?(maybe you can say)
  • dont worry about the brain first.
  • repair the conergence (three rectangules in the screen ***maybe not matching*** red blue and green) but perfect rectangule
Pencil:
To make this in your tv maybe you have +/-20 v maybe missed. the IC convergence amplifier damage. all resistors o some burn or different value or need new amplifiers. fixing this you get your rectangule.
Hand:
is easy to know in the copy of the program is corrupted first because the screens are miss matching that make some areas look as colored color Shadows but at least you can adjust up down east west each color in any point with the simple users menu. (you dont save in memory but your tv now looks now good adjusting here. but next day: bye bye adjustment.
the brain.
if your tv need this kind of solution. you need first to know how to navigate inside the manufacure native program. and second this kind of repair is so critical that you need to buy the parts that maybe have not program at all. and you need to download that with manufacture original program and make sure your program corresponds with the version of that particular tv (dont worry most of the time the program it shields perfect so most of the time you dont lost it, (but the don't even thing to start to dig in that area, better take it easy and resolve it in the other steps). good luck!
Apr 18, 2009 | Toshiba 57HX83 57" Rear Projection...
When connected DCR-SR42 to TV, video and images showing in B&W
yes ur TV might be set to color system PAL /NTSC and ur cam corder in opposite format there is color system changing button on every tv remote just try changing it to PAL or NTSC see if colors work and let me know and pls rate me if i fixed ur problem
Feb 25, 2009 | Sony Handycam DCR-SR40 Camcorder
Three separate images about 4-5 inch apart on my TV
Symptoms shows TV has problem of faliure of convergence out ICs. (2 ICs in TV) and need to be replaced.Let me know do you want to repair it at your own? ...
... if yes, it is necessary to have experience of TV repair and basic electronics knowledge.
Nov 23, 2008 | Sony KP-51WS500 51" Rear Projection...
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W19 52" Rear Projection Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
