Question about Dell Axim X51v Pocket PC
Except Start & time menu, No Icons and shortcut in screen. Even the start button doesn?t contain any links.
Problem : Except Start & time menu, No Icons and shortcut in screen. Even the start button doesn’t contain any links.
Error : if we click any external buttons “Error Opening the file or locating the target filename”
PDA : DELL AXIM X51v
Restored factory setting & working fine
Posted on Jul 31, 2008
I have a Toshiba laptop Satellite lAptopC-55-B5298 8.1
On a Windows 8 machine you have two places to put an icon for a program.
1. The start menu on windows 8 which is the first set of icons you see.
2. The Desktop, which is like the Windows 7 desktop and you put a shortcut here.
This is easy to do as you right click with the mouse and pick "new" then "shortcut".
Then pick browse and pick out the program file you want to run when the icon is pressed.
Then press "OK" and it is stored on the desktop.
On the start menu you have to go to the bottom of the icons to the down arrow.
Press the down arrow and it will take you to the "Apps", which is the list of installed program.
Then scroll sideways to the right until you see the program you want on the screen.
Pick the icon of the program you want on the start menu, with the right hand key of the mouse.
On the menu that pops up, pick "pin to start menu", and its done.
You can re-arrange the icons on the start menu by dragging them around with the mouse.
Mar 22, 2015 | Toshiba Computers & Internet
The icons wont come up
Problems with desktop shortcuts and icons
Shortcuts on the desktop do not work or are broken
Desktop icons are broken or have not been used in 3 months
Startup items do not work or are broken
System maintenance tasks
Free up disk space by repairing disk volume errors such as bad sectors, lost clusters, cross-linked files and directory errors click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors
then select check now start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
Free up disk space by removing error reports and troubleshooting history older than 1 month
Set the correct system time and synchronize system clock with the time server
You receive the following errors:
Windows update error 0x80072F8F
the item that this shortcut refers to has been deleted
hope this helps
Jul 05, 2012 | Computers & Internet
Desktop
I think you need to click right on desktop ...and select ..view..and click the show desktop icons ..try it ..and let me know if this solve the issue ..
Good luck !
In case you reinstalled it clean ..and this is the first time ..or you erased teh icons somehow..you just need to make new shortcuts ..
For the system icons..just click right on the desktop ..and select properties...and under desktop ..select desktop icons ..or change desktop icons..it is a link on the bottom ...of the window..selecting it will open a window where you can select the icons..and click apply ..
For windows 7 ...click right on desktop ..select personalize ..and in the left of the window select change desktop icons..and same thing ...tick the cases..and the main icons will be displayed..apply and OK ..
for the rest ..you need to make shortcuts ..from the start menu ..all programs ..one by one ...by clicking right on the program execution ..and select send to desktop ..
lets hope that this will not be needed..and it is a simple action like I explained in the first lines...
Dec 09, 2011 | Acer Aspire One D150-1587 Netbook
The appearance of my icons changed, they now have a small blue square with two right arrow symbyls in the square.
Instructions Things You'll Need:
  • Windows XP
    Change Default Icons in Windows XP
  1. Step 1 Start Windows in your normal fashion.
  2. Step 2 Click the Start menu and select the "My Computer" option. Alternately, you can double-click the "My Computer" desktop icon if you've enabled it to appear on the desktop.
  3. Step 3 Double-click on your hard drive to open the directory.
  4. Step 4 Find the program for which you wish to change the associated icon. You'll need to know its location on the hard drive. If you don't know where it is, you can use the Start menu "Search" feature to locate it.
  5. Step 5 Right-click on the file, and click the "Properties" menu option. This will open the Properties menu for the file.
  6. Step 6 Click the "Change Icon" button. If there is no "Change Icon" button, you will need to create a desktop icon instead. To do so, cancel out of the Properties menu and right-click the file again. This time, select "Send to -> Desktop (create shortcut)."
  7. Step 7 Click on one of the icons that appears in the list. If the icon you want isn't on the list, click the "Browse" button to search for more icons.
  8. Step 8 Click "OK" once you've chosen the icon you'd like to use.
  9. Step 9 Click "Apply" to confirm your changes, and then click "OK" to close the window.
  10. Step 10 Wait a moment to see the icon change. There are times, like when a lot of system resources are in use, when icon changes can take a moment to appear.
Jan 17, 2010 | Gateway GT5678 Desktop PC
All of the icons from the screen disappeared!
try to reboot your computer into safe mode.
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Then click start
click run
type in msconfig
uncheck everything under the startup tab except your antivirus
and reboot
Jun 05, 2009 | Computers & Internet
It takes my PC a very long time to boot up, what can i do?
If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
I put 2 steps to resolve this in order of simplicity.
Remove icons from the Startup folder
Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
NOTE: Removing items from the Startup folder does not uninstall the software program.
1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
2. Click the plus sign ( + ) next to Programs .
3. Click Startup . The shortcut icons are listed in the right pane of the window.
4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
Jan 11, 2009 | Compaq Presario 5000 PC Desktop
Inspiron 9300 Notebook start up problem.
There are a couple of different ways you may have lost your icons. They could have disappeared when you installed a certain program or even when you upgraded to a new operating system. Either way, you need them, so let's find them again! To enable those icons and more, right click on your desktop and choose Properties. Click on the Desktop tab and hit the Customize Desktop button. Next, under the General tab, check off any of the icons you want to appear on your desktop.
Jan 05, 2009 | Dell Inspiron 9300 Notebook
Wrong icon displays in the my computer
There are two ways to create a drive-specific icon. The first step for both is to determine the full pathname of the file containing the icon you want, as well as the index of the icon within that file. To view the icons contained in an EXE or DLL file, right-click any shortcut that links to a file (as opposed to a system shortcut like My Computer) and choose Properties. On the Shortcut tab of the resulting dialog, click the Change Icon button. Click Browse and select the file whose icons you want to peruse. When you find the one you want, count off the icons to determine the correct index. Start in the top left corner with zero and count down each column, then to the right. For example, icon 12 in C:\ Windows\System32\Shell32.dll is a picture of a memory chip. Make a note of the full pathname of the file and the icon index, then click Cancel, and Cancel again—you don't actually want to change that shortcut's icon. The Microsoft Windows files moricons.dll and progman.exe, both found in C:\Windows\System32, also contain numerous icons.
One technique for assigning a drive-specific icon uses a file named Autorun.inf in the root directory of that drive. Launch Notepad and enter [autorun] on the first line. Enter ICON= on the second line, followed by the full pathname of the icon-holding file, a comma, and the icon index. It might look like this:
[autorun]
ICON=C:\WINDOWS\SYSTEM\SHELL32.DLL,12
Save the file as "C:\autorun.inf" (you need the quotes to prevent Notepad from appending the .txt extension). Now restart the computer. When you open Windows Explorer, the drive should display its new icon.
The other technique involves editing the Registry. Launch RegEdit from the Start menu's Run dialog and navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\
CurrenTVersion\Explorer.
If a subkey named driveicons is present, open it; if not, right-click in the right-hand pane, select New | Key and name the key driveicons. Under the driveicons key, find or create a subkey named C (or the letter of the drive whose icon you want to change). And under this C key find or create a subkey named DefaultIcon. Double-click the (Default) entry in the right-hand pane and set its value to the full pathname of the icon-holding file, a comma, and the icon index. Again you'll need to restart Windows.
Feb 15, 2008 | Compaq NX6110 TFT XGA Notebook
Dell Axim X51v Pocket PC Logo
175 people viewed this question
Alun Cox
