Question about Dometic Rooftop RV Air Conditioner
Duo-Therm Air Conditioner short cycling at night
My air does fine in the daytime, but at night when the temp is reached
it will go off and on every few min. unitl I turn it off. This unit has never done this before.
Thanks
Cindy
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
My duro therm 15000 btu air conditioner runs fine until set temp is reached. The unit then starts to cycle on and off about every 2 minutes.
Service your indoor and out door. Due to over dusty, sometimes, this type of malfunction may happen. Thanks.
Oct 16, 2011 | Dometic Rooftop RV Air Conditioner
I have a duo therm air conditioner think thermostat problem
Google dometic rooftop air conditioning parts!Wouldnt suggest using off brand parts maybe diffrent?if that one is set up for 12v also maybe deffinatley diffrent!!!Try cleaning condensor aluminum fins on roof top if condensor is dirty will throw whole system out of whack!!!use oven cleaner and hose with nozzle be careful not to bend fins throughly rinse off cleaner after soak period spray off completly off roof and sides quickly!!!!!may damage decals etc!!! anyhow try that before replacing parts then use factory or alike parts!!!Good Luck!!!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
My Duo Therm Runs good until the outside Temp. Reaches about 75 dregees Then starts kicking off the braker. What would cause this?
Too many things on the same circuit. Try turning everything electrical off but the ac and see if it stops tripping the breaker.
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
Penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
My problem is the fan never goes off runs 24-7 and you can hear the compressor kick in from time to time. Is something wrong or do they all do that for a roof top unit? Any help on this one?
Frank
Jul 05, 2008 | Dometic Rooftop RV Air Conditioner
Will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Jun 03, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
106 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
