Question about Creative Labs Nomad Jukebox III MP3 Player
EAX Freeze DO YOU KNOW HOW TO GET PAST AN EAX FREEZE WHEN YOU START UP A JB III? Is there a way past this? Do I need to replace the hard drive? If so can I still get the OS off? Thanks for any help you can give me
I've simply reloaded the firmware when this happens . . . it doesn't delete your files, just reloads the firmware
Posted on Oct 10, 2008
My 01 Blazer is completely will not start. There is no turn over sound; Absolutely no sounds at all.
You could have serious trouble with the engine losing that much anti-freeze. If it is not leaking out somewhere onto the ground, it may be from a bad head gasket that is letting coolant burn in the cylinders (you would see white smoke out the exhaust), or it may let the coolant get mixed into the oil in the lower engine's crankcase.
Pull the oil dipstick and look at it. If the level is way high, or if the oil color is milky brown looking, then you have water (anti-freeze) in the oil-a bad head gasket, and a big expense to fix it. That would explain the rattling: water in the oil stops the oil from lubricating properly, and the engine bearings and other moving parts inside the engine can be damaged. If this is the case, and the reason for the rattling, then the engine is shot and needs a total overhaul, or you need a different engine.
If the coolant was leaking outside, post back. Has the engine ever overheated from low coolant? The rattling is worrisome-have a mechanic listen to it if you get it started. If it won't crank over, have someone see if the engine can be turned by hand-if it still turns freely (not siezed up), then the starting circuit needs to be checked for why the starter won't work. Good luck. Check the oil first thing.
Feb 08, 2013 | 2001 Chevrolet Blazer
I have done that allready,so it should be over the fins in the radator?
Always fill your radiator to the top. and make sure the overflow bottle is full to the high mark( if your model has an overflow bottle). Run the motor and after it cools down top it up again. The reason you do it this way is to make sure there are no air pockets in the head. Gas expansion there will push your anti freeze out of the motor and may damage the head.
It can be said for all motor cycle water pumps that if the engine gets hot it is easier for the anti freeze to leak past the water pump seal before it leaves past the radiator cap to the over flow. It is the steady/constant drip that needs to be addressed. I assume you replaced the impeller shaft as well as the seal. It is possible the seal was damaged during the install or one of the sealing cover o-rings or gaskets is leaking on the cover. If you can not ride safely with the amount of anti freeze loss, you should take the water pump apart, inspect, and consider replacing the seal and gaskets again. If the impeller shaft was not changed consider changing that to if there is any noticeable wear at all on the pump seal contact surface.
Use only non-silica formula anti freeze mixed 50/50 with distilled water. Gm Dexcool or any motorcycle anti freeze should be non silica. Silica content is stated on the anti freeze bottle. Silica scrubbing particles in the anti freeze will damage water pump seals in most Honda's.
Apr 17, 2011 | 2002 Honda CRF 450 R
How to disable deep freeze without a password
How to Uninstall Deep Freeze for Windows 2000/XP/Vista without the password.
Note: Without a complete uninstallation you may not be able to reinstall Deep Freeze on your system.
What we are going to do is edit the registry and delete the startup references to Deep Freeze. This will prevent the Deep Freeze driver from starting up the next time you boot. (c:\windows\system32\drivers\deepfrz.sys)
1. First we need a way to edit the registry. The way to do this depends on your situation. If your computer is thawed you can simply use Regedit. If your computer is frozen or if it doesn't boot you'll need to find another way. Here are some alternatives:
If you have a multiboot computer with another copy of Windows 2K/XP you can boot from there. Or, you can physically mount the disk on another computer that uses Windows 2K/XP.
You will probably use a tool that lets you boot and edit the registry. A good example of this is PE Builder that lets you build a Windows PE CD and boot Windows from there. Or use Bart's, http://www.nu2.nu/pebuilder/ or Winternals ERD Commander. There are several, including some USB memory sticks capable of booting like a CD. The goal here is to boot separately from your hard drive and access it while it is "asleep".
2. If your computer is thawed run Regedit. If it's not thawed follow one of the alternatives described above, and run Regedit (or Regedt32 on Windows 2K).
3. On the Find dialog box type UpperFilters and check only the Values checkbox. Then click Find Next.
4. The program will find a value with the name UpperFilters. Open this value and if there's a line with the name of the Deep Freeze driver (DeepFrz or DepFrzLo) delete it including the return, leaving the rest of the lines intact. Also, if you are using ThawSpace and you want to get rid of it delete that line too (ThwSpace), if you want to keep the ThawSpace leave it there. Press F3 to find the next match and repeat the operation until you have fixed all the UpperFilters values inside the HKLM\MySystem key.
5. Navigate to HKLM\MySystem\Select and check the value with the name Default. It has the number of the control set key that the system will use when booted. If it is 1 the control set is ControlSet001, if it is 2 the control set is ControlSet002, and so on. We'll assume the control set is ControlSet001 but you should use the one specified by the value Default.
6. Now go to HKLM\MySystem\ControlSet001\Services and delete the keys with the name of the Deep Freeze drivers (DeepFrz or DepFrzLo and DepFrzHi). Also, if you decided to get rid of the ThawSpace delete the key with the name of the ThawSpace driver (ThwSpace).
7. That's it. Now reboot and Deep Freeze will not load.
QUESTION: What if the BIOS settings prevent me from booting from CD or USB? Answer: Deep Freeze prevents you from decrypting the BIOS password, but it does not prevent removing it, if you have the right tool! Most of the BIOS hacking programs will not work to remove the BIOS password on a Deep Freeze protected computer, but CmosPwd by Christophe Grenier does.
You'll need to know how to use a command line and install the driver. Yes, it uses a driver to remove the BIOS password. But it works, even on Deep Freeze protected computers. Use CmosPwd to remove the BIOS password and reset the default BIOS settings. Then you'll be able to boot from CD or USB and edit your computer's registry and remove the DeepFrz, DepFrzLo, and DepFrzHi references which start Deep Freeze.
Now here is a little known secret: Faronics (the makers of Deep Freeze) uses a special driver to remove broken or malicious Deep Freeze installations. They do not have any backdoor passwords, so they use a special driver to remove a Deep Freeze installation where the password is not known or that someone is having trouble with. Will they send it to you, or even admit to you that they have it? I don't know. But, even if you do have it, you will still have to boot separately from the hard drive and replace the existing Deep Freeze driver with the special one and reboot. And after that, you need to use a Deep Freeze installation file to fully uninstall Deep Freeze (it will be thawed when you boot up with the special driver). If you want to re-install Deep Freeze, you'll have to first delete the special driver too.
Only a few people have this driver. It is the only solution Faronics has for those who need to remove Deep Freeze without the password. And, like I said, you will have to be able to boot from CD or USB and access the NTFS hard drive. If the boot-up order is locked (hard drive first and only) in BIOS settings, use CmosPwd to reset BIOS and boot order. Then you can boot from CD or USB.
Booting from CD or USB and removing the registry references works also, but then you should uninstall Deep Freeze with an installation file once you are able to boot thawed.
If you are dealing with a trial version of Deep Freeze, just forward the BIOS date past 60 days and then restart.
If anyone is wondering if Deep Freeze has ever been hacked, the answer is "yes" it has, several times over the years. Most of the time these were weaknesses that Faronics was able to quickly fix or prevent. However, there was one hacker that really, REALLY gave them headaches. His name was Emiiano Scavuzzo from Argentina. He was really good at low level programming and used OllyDbg to come up with about five versions of his "Deep Unfreezer" which gave Faronics their greatest challenge to date. Deep Unfreezer now only works on older versions of Deep Freeze.
Faronics is doing very, very well right now (as of 2008). They sold Apple Computer their Mac version of Deep Freeze, which, if you know how to look for it in the Applications folder on a Mac, is used in all the Apple Stores on both their desktops and their laptops. So, if you're ever in a Mac store playing around with PhotoBooth or whatever, and the computer settings are all messed up, just restart the Mac and thank Deep Freeze.
Apr 11, 2010 | Computers & Internet
Hard drive crashing
What size hard drive is it?
There is a know problem with Seagate 80GB sata 2.5 Mobile Hard Drives (example Apple Macbooks 2005-2006 had these drives), The drives were extremely faulty and several manufactures have extend their warranty's to 3 years for these faulty drives.
Feb 25, 2010 | Gateway MT6705 Notebook
For the past 5 years i have had to replace the radiator in my 2002 ram 1500. I always starts to leak on the driver side plastic tank. What causes this, I do not haul heavy loads nor do I drive hard?
allways use the correct anti-freeze and distilled water. tap water has stuff in it that under heat and pressure will corrode alot of materials
Nov 26, 2009 | 2004 Dodge Ram 1500
Load Screen Freeze w/ Roland VS-2400
The hard drive needs to be replaced. You can contact their customer service as to how to do this. It is relatively pain free and inexpensive as well.
323-890-3741
Mar 19, 2009 | Roland Vs2400CD Digital Workstation W/CD...
NEW ACER ONE NETBOOK WILL NOT BOOT UP
Try Safe Mode.Disconnect every device (Mouse also)
Hit F8 at very beginning until you get a list of options select Safe mode and check if Windows starts.
then try step by step confirmation option.
say yes to every request until freeze: last driver you accepted to load is the culprit.
Remove it in Safe mode using Start/Run/Msconfig
Dec 26, 2008 | Computers & Internet
I cannot copy files
I used to get this problem until i updated my USB drivers. Or try a different USB port. I only have USB 1.1 and this device is 2.0. They should be inter-compatible but you know how these things are sometimes. Make sure the temp of the drive is reasonable too, I've not had heat problems with this one but i have with other external drives in the past.
Hope something I've said helps.
Oct 28, 2008 | Western Digital 250GB MyBook External USB...
My WD MyBook 500GB drive is causing Windows XP to be self-retardant. (Slows)
Heres what you do.
Don't plug your external HD in while the computer is booting up. It's looking for Windows on your external hard drive. Hence the black screen.
Plug your USB or Firewire cable back in once Windows is finished booting up.
Mine does that sometime too.
Jun 13, 2008 | Western Digital My Book Essential Edition...
My Creative Nomad Jukebox III will not start. At best, I can get to the EAX screen: this is accompanied by some whirring and clicking (HDD activity?) and then it freezes. On one occasion, it got past this...
I had a failed JB III that acted the same way. I thought it was the hard drive, but turns out it was the motherboard in the player. I bought a used one on EBAY, then transferred my old HDD to the new one (the JB III uses a standard notebook hard drive).
If you're not worried about losing your songs, you can remove the HDD, get a PATA-to-USB external HDD adapter (less than $10 on sale), and reformat the drive, and test the drive to make sure it's sound. If it is, then you have a new portable hard drive. Unfortunately, your JB III is now an empty shell.
This article explains how to perform the "operation" on the internal hard drive: LINK
Feb 13, 2008 | Creative Labs Nomad Jukebox III MP3 Player
Creative Labs Nomad Jukebox III MP3 Player Logo
94 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
