Hi my Sony RCD W-100 will not finalize a recorded disc, but will play back ok only in the recording disc tray after recording. But i can not
play it in any other machine ,due to not finalizing.
Any suggestions
Thanks
Rob.
using the dubbing button on your recorder will recorder from your cd player on the right side of the deck to the cdr recorder on your left side..the left side of the deck is the cd recorder...hope it helps...just place a cd disc on the right side and a blank cd on the left side push dubbing button and wait till the left side reads the song on the recorder cd on the right
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Could it be that you THINK there is no audio recorded because you can't hear it, but there may be a setting preventing the audio from emerging to a reciever or whatever you're listening through?
IOW: there is more to this than just the Sony. What happens if you take the CD somewhere else and try to play it?
Higher laser power is needed for high speed dubbing - does it work ok at normal speed? If so would point to a failing laser. Sony charge a lot for these but in the US there may be a fixed fee out of warranty repair cost.
