Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Cleaning under floor nozzle window
I removed screws from the clear window to remove build up but can't remove it. How do I get it off?
    Problem Solver:
  • 7 Answers
Make sure you removed the 2 screws closest to the front then lift up on the front end of the window sometimes its sticky but it will lift up. when putting it back on put the tabs on the back end in first then slip it down in the front , replace 2 screws
Posted on Jul 29, 2008
My carpet cleaner bissell pro heat wont extract the water from the carpet
1) Remove the Tank-in-Tank Assembly and place your hand over the motor intake valve. This valve is located next to the Floor Nozzle gasket (at the top of the Floor Nozzle window) and behind the SmartMix Bottle. If you feel vacuum-like suction at this area, your suction power of the unit is working but air is escaping at some point. If there is no suction at the motor intake valve your machine will need to be inspected by an Authorized Service Center Technician.
2) It is possible the Floor Nozzle on your machine is inserted incorrectly. This would directly affect the suction of your machine. Please follow the directions below for removing and replacing the nozzle.
Before starting, please be sure the machine is unplugged and the machine handle is reclined.
To remove the Floor Nozzle window, first detach the Phillips head screws located at the base of the nozzle. Then, remove the Tank-in-Tank Assembly. Next, pull forward at the top of the Floor Nozzle window to release the tabs of this window from the receiving holes of the machine. This window is designed to allow access for cleaning.
When replacing the Floor Nozzle window, please be sure the tabs at the TOP of the nozzle are properly inserted into the receiving holes provided. If you do not have the tabs in place properly, the suction power of the machine could be affected.
Rotate the window down into place and replace the screws.
3) Ensure that the Ready Tools knob (diverter knob) is in the proper setting and the valve opens and closes freely. Ensure the black foam gasket is in place under the valve.
4) Check to ensure the Tank-in-Tank assembly is seated properly and that it is not full of dirty water. (If this tank has a drain cap, make sure it is in place and that it has a black o-ring).
5) Check the float and baffle to ensure they are properly installed on the Tank-in-Tank. The larger square portion of this part should be below the clear baffle of the tank with the red flag portion of the float resting on top of the baffle.
6) Check the Tank-in-Tank and lid for damage. Is the lint screen clogged? Make sure the lint screen is in place on the tank lid and not placed into the motor duct. Also, clear the holes on the lint screen.
7) Check to see if the upholstery hose has suction. If the hose has suction and the floor nozzle does not, check the diverter valve to see if it opens and closes freely. This can be seen through the Floor Nozzle window as you switch the diverter knob from the floor to tools setting.
If these suggestions do not solve the problem, please have a technician at a local BISSELL Authorized Service Center inspect your machine. BISSELL supports your machine with a one-year warranty for any defective or malfunctioning part.
Nov 22, 2010 | Bissell 8910 ProHeat Clear View Upright...
My bissell powersteamer isnt suctioning the water
Please try the following suggestions to see if you can get your machine suctioning properly:
Nov 05, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
The cleaner no longer vacuums up the water. I have to use the tool device to get the water up. marleneodlekemp@hotmail.com
Try the following suggestions to see if you can get your machine suctioning properly:
Aug 11, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Vacumm not working shampoo the rug but does not pick up dirty water
Aug 04, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
The cleaner will not remove the water from the carpet. I have cleaned as much of the cleaner as I can reach. Where is it stopped up or what is wrong
If these suggestions do not solve the problem contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My power steamer seem to be putting down water and scrubbing but it's not picking up the water it puts down. Also, it doesn't seem to be using any of the cleaning solution
Trythe following suggestions to see if you can get your machine suctioning properly:
Jul 14, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
The bissell proheat will not suction
Jun 15, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No suction
Jun 15, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
My bissell will not **** up water
May 19, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
How to clean
I have found this so i think this answers my question.
Question         How do I remove the clear floor nozzle window on my machine?     shim.gif     Answer         Before starting, please be sure the machine is not plugged in and the machine handle is reclined.
To remove the clear floor nozzle, first detach the phillips head screws located at the base of the clear floor nozzle. Then, remove the tank in tank assembly. Next, remove the rectangular gasket at the top of the nozzle, and pull the clear floor nozzle forward to remove the tabs from the notches. This clear floor nozzle is removable so you may be able to access this area and clean.
When putting the clear floor nozzle back in place, please be sure the tabs at the TOP of the nozzle are properly inserted into the notches provided. If you do not have the tabs in place properly, you may have a problem with the machine's suction.
Rotate the window down into place, replace the screws, and replace the rectangular gasket.
If you would like additional assistance, please contact BISSELL Consumer Services at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET or email us by clicking on the Email BISSELL tab at the top of this page.
Reminder: When you have completed the deep cleaning process, it is recommended to return the SmartMix dial to "Water Only" prior to storing the machine.     shim.gif     How well did this
Oct 10, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
400 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
