A letter "L" and a number "1" appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch. Hope this helps. Good luck.
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting. If its the scanner, unlock the scanner lock above the paper exit tray.
Please check out the following website and see if you can find your error code: http://www.copier-help.com/copier-help/
E7
03
Scanner position error
04
Exposure lamp blown
05
CCD calibration error
12
White level calibration error
14
Main board malfunction
15
Exposure lamp blown
L1
00
L3
00
L4
01
Main motor drive overloaded
L6
10
Polygon mirror motor not up to speed
H2
00
Fusing unit temperature error
H3
00
Overheated fusing unit
H4
00
The fusing unit doesn't heat up
U2
01
Counter error
04
EPROM error
CH blinking
Dev unit is not properly installed
hi i think this is carrage home position sensor problem. u check and clean the sensor and try it back. or any forign meterial blocking in carrage way.. pls check that also.. all the best..
