Question about ViewSonic Computers & Internet
My screen has a picture for 1 second then shuts of> I have a viewsonic vg 700
  • nmavrou Jul 29, 2008
    my screen has a picture for 1 second then shuts of> I have a viewsonic vg 700
If it is like that constantly, it sounds like the lcd screen is going out. I had the same problem with mine.
Posted on Jul 29, 2008
I was trying to upload pictures from a Olympus VG-110 micro sd flash drive. and i couldn't see the files saved in it.. why is this happening? Then we put the back the disk in the digicam and after turning...
SD cards (and most microSD adapters) have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
And yes, formatting the card will delete all the pictures on it.
Sep 13, 2013 | Olympus Vg110 Vg-110 Red Digital Camera...
I have a panasonic TC-p50x3 and a radeon hd 2600 pro with an ultra 700 dvi to hdmi cable and cant get picture to my tv from pc
hello,
To see the picture to your TV from PC you need to set the second monitor to be displayed,please follow the instructions below:
1.right click->properties
2.display setting (you should see a monitor marked 1 and a smaller one marked 2
3.connect the cabels
4.my computer->right click->manage->scan for hardware changes-you should see now two monitors
5.click on smal monitor marked 2,click on "extend this desktop onto this monitor->click Apply->pop up window"Do you want to keep these display setting?" click "yes"
6.if you want to move something from monitor 1 to monitor 2 simply drag-and drop
Mar 01, 2012 | Panasonic Televison & Video
I have a problem with a gift from my sister, she gave me a viewsonic n2750w that she gave up on once it started to turn on and shut off on its own, i took it to my place, turned it on, the screen turns on...
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.The board is a long in shape.
Mar 22, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Monitor displays then shuts off
Have you verified the video card in the computer with a different monitor? Does the going to sleep message come up prior th the monitor going dark? The bulbs are ok since you do see a picture for a short time. The voltage swing you see on the power supply is too large. It should always be 12 v + or- 10%.
Mar 28, 2017 | ViewSonic VG900b 19" LCD Monitor
I want to repair my dead monitor. Can somebody help me and explain how to remove the back cover to access the electronic board of Viewsonic LCD Monitor Model VG 700. Thanks
First take the speaker cover off the front by working it from the top of the cover on both sides with your fingers. It should snap out top first. Then unplug the cable that connects from the main board to the cover. After that take out the 2 screws from the bottom of the front silver cover. them you take off the silver housing on the front by pushing it towards the top from the bottom. do not pull out on it. It seemed easy if i applied the pressure using my thumbs while holding on to the black parts with my fingers.
Again. the silver front slides up about 1/2 inch and falls off. don't pull out on it.
After that take out the 4 screws that hold the screen into place.
The screen then needs to be pulled gently from its housing. Around the screen there is a metal house that holds it in. The metal houseing does nt come out. The screen needs to be gently worked out of it. I started with one corner and the rest came easily.
Pull it out slowly to make sure you don't put strain on any wires.
Hope that helps.
Sep 20, 2009 | ViewSonic VG700 17" Flat Panel LCD Monitor
Need tip size for viewsonic powere supply
insidecomputer_2070_4186448
Replacement Part Number: 1267-0526
Specs:
  • 40 Watt, 12 Volt AC Adapter
  • 4.8 mm Barrel Connector with Positive inside
  • Condition: New
  • Warranty: 12 Months
  • 100% OEM compatible, Guaranteed to meet or exceed OEM specifications
Compatible Models:
  • Hewlett Packard Jornada 680 Series
  • Hewlett Packard Jornada 720 Series
  • Hewlett Packard Jornada 728 Series
  • HP Jornada 680 Series
  • HP Jornada 720 Series
  • HP Jornada 728 Series
  • Planer LP150-BK
  • Viewsonic VG150
  • Viewsonic VG-150B Model
  • Viewsonic VG151
  • Viewsonic VP140
  • Viewsonic VP150M
Sep 07, 2009 | ViewSonic VG151 15" Flat Panel LCD Monitor
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
Screen Keeps turning off after about 1 second. I turn it on and can see the desktop for about a second then the screen shuts itself off.
Have you tried booting into safe mode? This will also provide a safe video mode. During bootup, press the F8 key. Arrow down to "Safe Mode" and press the enter key. If the monitor still does it after this, chances are it is bad.
Mar 10, 2009 | ViewSonic VA902 19" LCD Monitor
Viewsonic VG 900 displays briefly, then goes blank
What Usually causes these to go on and off quickly is one af a couple things.
Usually it is the powerboard not putting out enough power to run the video board and the inverter.
Sometimes it is the actual inverter board. I have seen a plain small fuse stop these cold.
Rarely, but it could be a bad bulb in the screen. Bad bulbs usually start dark in the middle, or they start off pink. They can also flicker while they are on.
If you can take it apart and have a dc tester, the problem may be able to be found.
I repair some viewsonics , mostly VXs series, but I have done a couple of these.
bammbammfran
Oct 11, 2008 | ViewSonic VG900b (Black) (10 Pack) Monitor
Computers & Internet Logo
62 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
