Question about Microwave Ovens
It start up when the door is open - Microwave Ovens
  • Microwave Ovens Master
  • 9,098 Answers
If you reply back with your brand and model number we may be able to help you better, but here is our standard reply:
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
When I open the Panasonic microwave oven door by pushing in the door opening button, the oven starts immediately
There is evidently a fault with the door interlock switches. Don't use it as the oven may avtually be emitting microwaves with the door open.
Get a service tech to quote you for repair as it may be more economical to buy a new one, when you will have a warranty.
Do not try to repair it yourself unless you have detailed knowledge as there are components inside which can deliver a lethal shock even when the oven is not plugged in.
Sep 30, 2016 | Panasonic Microwave Ovens
Unit starts when door is open
This is most likely just the blower, and cooling components firing to begin air circulation around the magnatrons, If the mags are firing with the door open you would have burns and radiation poisoning if you were too close. Microwaves produced after the late 80's have many fail safe features to prevent the unit from generating cooking energy with the door open. If you still feel you are having issues with this I will need a model # to better help with the problem.
Apr 19, 2014 | Amana AMC7159TAS 1000 Watts Convection /...
Ge pvm1870DMWW
Verify the door micro switches.
Aug 30, 2017 | GE Microwave Ovens
My nn-s963bf starts operating when door is opened
The electronics have lost their marbles. When a nuker door is opened the safety switch connected to the door is designed to turn the unit off and not on. You just better work fast when you put stuff in or take it out!!!!!!!
Nov 24, 2013 | Panasonic NN-S963BF Microwave Oven
When you to start the microwave the screen tell you the door open even though the door is close.
you need to adjust the door travel adjustment on this micro-switch,if its open and registering open the control board will not let the unit start due to R.F. radiation safety concerns,you should adjust the door and after it starts to operate,have the R.F. leakage at the door checked to make sure your safe and till so don't stand too close till its certified so
Apr 26, 2010 | Whirlpool GH5176XPS Microwave Oven
My JE 1860 microwave starts working when I open the door.
It sounds like the door switch is bad. It may be that the switch is shorted inside. I would think it may really run with the door open, and microwave you.
Mar 06, 2010 | GE JE1860 Microwave Oven
MIcrowave runs with the door open also
your door switch is mis-adjusted,furthermore the other safety switch on the door should have blown the power fuse in the unit,because by design for safety it produces a short circuit if door opens under operation,so if door was taken off and replaced it was not adjusted properly
Aug 15, 2009 | Sanyo EM-P790 Microwave Oven
Microwave door won't open when I push the button!
check door open mechanism, any broken change the mechanical parts,
Oct 27, 2007 | DCS CMO-24-SS Convection/Microwave Oven
Sharp carousel under counter microwave start doesn't always work
Sounds like an intermittent door switch or a loose door switch mount. Very common.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 14, 2007 | Sharp R-9H66 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
