Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
Amp problems my alpine amp just cut out one day and never turned back on, i found that the positive wire goin from the battery to the amp was split because of my hood hing. i bought a new wireing kit but the amp still wont turn on. i checked all the wires and everythign appears to be hooked up right. i also just to make sure my alpine amp wasnt blown i hooked up my 800w kenwood amp and that wouldnt turn on either. if you could help me witht hsi i would really appreciate it
    Sergeant:
  • 300 Answers
The main thing that comes to mind is whether you've checked the in-line fuse on the positive wire. Most amp installations are supposed to have a fuse within 1ft of the battery terminal for just such a reason. Next, if you have a voltmeter of some kind (or know someone who does), check to see if you still have 11VDC-14VDC at the power terminals of the amp. If you do, then check the remote turn-on lead (which is supposed to connect to either your head unit or the ignition). If my memory serves, the remote wire should be high (about 12V) when the amp is being told to turn on and low (less than 2V) when it's being told to turn off.
Posted on Jul 29, 2008
2 Suggested Answers
  • 631 Answers
SOURCE: car amp wont turn on
I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Subs cut in and out
The amplifier may be going into protect mode (even briefly) because you are driving them too hard. Back off on the volume and see whether the problem goes away.
Mar 11, 2017 | Alpine MRP-M1000 Car Audio Amplifier
My alpine keeps shutting down when the volume is turned up past 20. Plus I have no sound coming out of my subs. I tried switching rca cables. And I sent my amp off thinking it was my amp. Their is a little...
so it turns off suddenly and then the next second it turns back on and starts playing
from that and personal expericance i belive that the radio system (radio and amp) is not reciving enough power
is this radio inside a car
if so what car
what i would do is attach bigger thicker wires to the positive and negative of the amplifier
direct from battery
positive of battery>>>> positive of amp
metal grounding point on car>>>>>> negative of amp
(do not use negative of battery use the metal of the car)
May 12, 2010 | Car Audio & Video
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Car amp wont turn on
Jul 29, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Cut out Alpine 9855
When you say you connected the blue and white wire to the amp power do you mean the remote turn on of the amp and not the terminal/wire marked battery or power? You should not be trying to power your amp with the blue and white wire. This wire is only for sending a signal(+12V) to the amp to turn itself on. the amp should have it own fused wire of appropriate gauge running directly to the batttery. Some more details on the installation would be helpful.
Aug 14, 2007 | Alpine CDA-9885 CD Player
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Nov 12, 2006 | Alpine MRP-M450 Car Audio Amplifier
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
252 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
