Question about ASUS P4P800 SE (890552603657) Motherboard
I need help
Any suggestion for overvoltage cpu it restarts after 15-30 seconds and then pressed the power switch again then shows overvoltage press F1 to resume.
  • 781 Answers
First off check the CPU fan operation then check the heat sink is clean and has no dust in the vanes etc.
otherwise go into bios and you will have to go to the page that controls CPU and check settings are for your CPU and not overclock settings
Posted on Jul 29, 2008
Smart failure.. bootmgr is missing..I have recovery discs but dvd player is not working
Yes, you can make USB boot drive. However main problem is the Smart... error. It is your hard drive. You need to fix that first! Try reseating the drive. Next go into BIOS by pressing F key during boot. Might be F2? Make sure BIOS recognizes the hard drive.
Once you get the drive going again, you can start the install / repair again. USB drive tool.
http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
Oct 11, 2012 | Computers & Internet
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
My computer boot but switch off in 5 seconds after mountong it on a new case
HI,
Do this first step power on your CPU, then press F8 to show safe mode highlight and select
Last known good configuration(advance),then press enter key.
If switch off again.try this second step open cover of CPU get your hardisk and install to other CPU desktop need slave only to fix the data cross link and viruses if have.
Clean bad sector and viruses (if have), then connect again to your CPU
Just let me know if same problem again.
thanks for using Fixya.
Jul 14, 2011 | Computers & Internet
Whe i make power button on, he press f1 to BIOS setup utility and press f12 for temporary boot device. when i hit f1 or f12 after some minit, he display just like lock icon on screen and some times says...
Check the laptop is booting by connecting it to an external monitor and see if the lock appears there you may need to press Fn and F7 keys to switch display
If it does not, then try pressing Fn and scroll lock
Jan 10, 2011 | Computers & Internet
Dear All, When we start Deaktop come erorr "CPU overvoltage error" Press F1 We reinstall OS,remove Fan and pest Hit sniak,Change SMPS but same problem comeCPU overvoltage error" ...
hi yadav, i think you have tryed al, i am sure there is no problem with your CPU or SMPS , i think your motherboard got shortcircuited , just try this steps if nothing work mean you have to replace your Motherboard yadav.
step 1 - Try resetting your BIOS settings to default
step 2 - Do you have the AUTO Overclocking feature enabled? If so... DISABLE it.
step 3 - try a BIOS upgrade
Good luck ! if you think your problem solved don't forget to rate
Jan 03, 2011 | ASUS P5PE-VM Motherboard
AMD Phenom-II is installed in Asus M4A78LT-MLE motherboard. While system is booting showing error message -" This CPU is not supported by this model. Please check CPU QVL on Asus website" Please...
the only phenom-II cpu's it supports are the 545 and 550 socket am3 1.01ghz. if you have anything other it will not run. here is complete cpu support list here
Nov 04, 2010 | ASUS M4A78LTM LE Motherboard
Problem with ASUS P5GD1 mobo
Is the cpu fan working, remove all the memory,but one stick, then try each stick you have. Then, When you get your post, enter safe mode, this does not use full video, so if you can, and it works in safe mode, it is probably your video, if not it is either
your power supply or another piece of hardware.
Unless you installed something on windows just before this problem.
Post back if you need more help, any code errors would be great to post.
Feb 05, 2010 | Computers & Internet
CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Nov 24, 2008 | Abit AB9 Pro Motherboard
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
ASUS P4P800 SE (890552603657) Motherboard Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
