Mitsubishi ws-65113 has constant green light,will not power on
  • 1694 Answers
SOURCE: mitsubishi WS-55513 won't turn on
Two choices =
1) Replace DM MODULE. 650.00 is right.
2) Rebuild DM MODULE. Done right = a little less than Mits.
Caution: High degree of skill needed and ask about warranty
in either choice.Rebuilds usually cover only parts installed,
not complete module.If you do the research on repair,you
will find pin push reset does not work,in most cases....T.
Posted on Nov 05, 2007
  • 1030 Answers
SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Posted on Jan 08, 2008
SOURCE: constant green blinking light Mitsubishi tv WS-65513
Hello all. I have fixed my green blinking light problem on my Mit. 65513 rear project. hdtv. It is on now as I'm writing. I replaced 4 capacitors on the DM board (largest vertical standing board). I used a desolder tool from RS($15).I practiced on a discarded board first. I replaced the caps with 4 radial capacitors rated 1000uf 16v. 105 degrees c and was sure to match the polarity markings on the board(+/-)with the markings on the capacitors. That's it! I also installed a small 12v PC fan(wired to a 12v wall adapter) on the DM module casing with zip ties. You may also use 1000uf 25v 105c caps. I hope this helps-good luck!
Posted on Jan 30, 2008
  • 7 Answers
SOURCE: Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Posted on Jan 14, 2009
Slinteriors
  • 8617 Answers
SOURCE: I have a Mitsubishi HDTV 1080, model #WS-55511 and the green power light is blinking on and off. We've used the paperclip to reset the machine and it doesn't work, and we've unplugged the power supply
replace the capacitors on the DM board. Heres a link to the repair kit which contains the replacement capacitors and instrucions of how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on May 11, 2009
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green timer light blinking constantly, no picture
You need the V21/V19 DM repair kit thats available at the following link, it contains the parts and step by step instruction CD so you can do the repair yourself. Its listed under their repair Kit category.
Aug 21, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi ws-65515 tv green light blinks constantly after power failure.
I UNPLUG IT AND WAIT A FEW MINUTES...THEN I PLUG IN THE POWER AGAIN AND IT WORKS
Jun 11, 2008 | Mitsubishi WS-65515 65" TV
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Will not power on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Dec 09, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
