Question about IBM (10l1433) (  10L1433) Motherboard
T60 after Bios Update to Ver. 2.22 no Video
I need very urgent help.
I have run an bios update under windows xp sp3 to version 2.22.
In the middle of the update i got an bluescreen. since this happens the is no video an nothing else to see at boot time.
is there an possibility to make an bios recovery boot?
thanks for your help
  • 781 Answers
I do not know if this will work
1)open case
2) check motherboard for word which will say reset bios or words to that effect nearby will be a small 2 or 3 pin connector with the 2 pin remove the jumper from 1 pin and fit over both reboot and turn off straight away refit jumper back over 1 pin and reboot see what happen it may work
with 3 pin setup jumper will already be over 2 pin remove and fit over middle and the other pin remove reboot etc
Usually a failed bios update is more often than not fatal
hope this works for you if it does post favorable rating thanks
Posted on Jul 29, 2008
Bios update
How to Update Your BIOS
By Patrick Miller, PCWorld
  • Jan 21, 2010 6:00 PM
  • Check your BIOS version, without restarting your PC, by using msinfo32.exe (as described in the text).187437-versioncheck_original.jpgThe easiest way to find your BIOS version is to open up the System Information app in Windows--just type msinfo32 into the search bar (for Windows 7/Vista) or the Run box (XP), and clickSystem Summary; your BIOS version should now show up on the right under your processor speed. Record your version number (and the date that appears afterwards, if applicable).
    Step 2: Check your PC/motherboard manufacturer\'s Website for BIOS updates.
    Most PC manufacturers handle BIOS updates based on your specific line and model, so head over to your manufacturer\'s support page and check its listings for your PC, because if you download and install a BIOS intended for a different model, your PC probably won\'t work (although most BIOS updaters are smart enough to notice if you try to install them on the wrong hardware). If there is a BIOS update file available, grab it--along with any documentation it comes with, because often warnings and specific instructions are contained in the Read Me docs.
    Those of you who assembled your PC yourself will need to look for BIOS updates from your motherboard manufacturer\'s Website. If you don\'t remember your motherboard\'s model number, you can look it up without opening up the case by downloading and running CPU-Z and clicking on the Mainboard tab.
    Step 3: Read the included documentation.
    Your PC\'s BIOS handles a lot of the nuts and bolts ISO Recorder for Windows XP or the version for Windows 7/Vista) to create a BIOS update CD.Other systems will have you copy a few files to your bootable disk, restart, and open up the BIOS during startup (typically by pressing a specified key for setup options), and change the boot order so your system looks for a bootable USB drive or CD before loading the OS from your hard drive.
Dec 13, 2013 | Acer Q45t-am Motherboard Intel Q45 Ddr3...
Bios update version for hp a1420n
keep the flash drive in hand. try to install xp. while install it was asking for bios update and ask for press f8 for bios update and insert pen drive and select the path it will automatically update the bios and start installing
Apr 03, 2012 | HP Pavilion a1420n PC Desktop
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
BIOS update
Dear Friend,
Here is Download Page Click Here Select your Operating System.There you can Find Bios Update Driver & so..
OR Try this Link Click Here I think THIS WILL HELPFUL to you....
I like To KNOW FEEDBACK Thanks For Using FixYa
Apr 09, 2010 | Asrock 775VM800 Motherboard
I have an old ibm net vista with ms 2002 xp sp2,i have downloaded 2008 xp sp3. and would like to replace the old os with the new version. can this be done.
Hello nymandavid,
Yes it can be done. I would recommend you turn on automatic updates and let windows find the update for you, or run the windows update program from the start menu and install that way. The individual file of the SP3 update that is available on Microsoft's site is intended for large installs where more than one machine is being updated. Windows Update has a much smaller SP3 file that takes less time to install. I'm not sure what version of the SP3 update you have without more information on how you obtained it, but I would recommend not using it and following the examples I've given you.
Hope this helps, and remember to leave feedback if you found this to be helpful. Thank you.
Feb 16, 2010 | Microsoft Windows XP Home Edition for PC
Do I have Windows XP SP2 SP3?I need help please!
your game requirement says the minimum requirement is SP2 but recomemded SP3, your game still runs in SP2
Sep 18, 2009 | Microsoft Computers & Internet
Hi i have Aopen computer and nvidia geforce 6600, i install the latest driver but when windows running the monitor is blank
You may want to boot into bios and see if the video display is set to agp or pci and change it from their than save and reboot and if that does not help boot into the safe mode and uninstall the update and if needed reinstall the card,,, geforce has been having a problem with these updates and depending on your operating system it can be non compatable so, please try these solutions ok
best regards michael
Sep 15, 2009 | XFX GeForce 6600 GT, (128 MB) Graphic Card
BIOS "Phlash" Error
pls run an earlier version of windows xp i.e. sp1 as earlier processor and motherboard may run xp sp 3 but it will not provide 100% compatibility
Jun 23, 2008 | E-Machines eMachines Desktop PC
IBM (10l1433) (  10L1433) Motherboard Logo
191 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
