Question about HP Pavilion dv6000z Notebook
Lightscribe Because i changed it to the high density, did that mess up the buffer?
  • Justin
    Justin Jul 30, 2008
    no i haven't. but i will. thank you.
    Problem Solver:
  • 44 Answers
No, it didn't mess up the buffer, it just means that the image you are trying to scribe is too dense for the capacity of the buffer. Have you tried it again with the low density?
Posted on Jul 29, 2008
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
How do I activate the option to burn an 8.5GB DVD+R DL using LightScribe HP dvd1070? I am using Roxio Easy Media Creator 10.
That option would be set in Roxio, not the drive itself.
Make sure that your machine meets the requirement for speed and memory required to write DVD's at this density.
Dec 22, 2009 | Lite On LightScribe (HP640VI) (HP640VI)...
I have a PC with an ASUS P4B533-VM MoBo. I got
Hello.
According to Crucial, your MB takes either DDR PC2700, or DDR PC3200, NON-buffered, NON ECC modules. Another consideration is density. Some cheap high density modules will not work in all MB's.
Refer to:
http://www.crucial.com/store/listparts.aspx?model=P4B533-VM
Have you tried to see if it will POST with just one module installed? Try both individual modules and see if there is any success. It may be that one is bad.
Thanks for using Fixya.
Wayne
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Half of my tv screen is not showing a picture
Check the connections on the buffer boards to the panel. Likely connection or bad buffer board.Change buffer board . If this does not fix then Panel is bad. Try C board connections on bottom. Be sure to disconnect power supply from sustain boards before messing with these connectors to avoid burning the flex cables.
Oct 31, 2009 | LG 50PX5D 50 in. Plasma HDTV
TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Aug 28, 2009 | Epson TM-T88III Thermal Printer
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
Malfunction detected C-0096
Code Item
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
Feb 10, 2009 | Kyocera Office Equipment & Supplies
Lightscribe problem.
Dear JustinMule,
If your lightscribe won't finish making the label, check the label quality and make sure it's on the basic setup (there is a high density option). See if that helps, if not you may have a buffering problem with the burner.
Jul 29, 2008 | HP Pavilion dv6000z Notebook
Emachines T2240
low density works alot more often then high density, HD is just cheaper and thats mostly why it't not compatible with as many boards.
Good luck,
Lee
Jun 11, 2008 | E-Machines T2240 PC Desktop
Memory
you must try reseating the memory as the beep code suggest that the memory are not there or not plugged in properly.
check if you are using the right memory card. If not u need to change them.
Jun 05, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
