Question about LG Flatron 295LM 22" LCD Monitor
Dimming the brightness
How do i cut the brightness on my monitor? i bring that screen up but my mouse just goes under the fix screen
    Champion:
  • 293 Answers
Hey...Mama of many,
Try used your fingers press on the buttons on the monitor and the on screen will appeared. Then just press the next button until you reached the icon (brightness.) Next used the - and + to changed the brightness. Have a nice day!
Posted on Sep 29, 2008
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
No longer bright
you might have a busted ccfl lamps or defective inverter circuit, bring the unit to a shop for servicing...
May 07, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Dim screen, bright mouse pointer
Right click the battery icon on the right bottom of the screen in the task bar. The performance profile may be set to energy saver causing monitor to dim to save energy.
Sep 09, 2009 | Gateway Computers & Internet
Lower half of monitor goes dim
Replace the backlight in this unit will bring you back in business.
Thanks please rate.
Aug 19, 2009 | Star Logic 17" LCD Monitor
Treo 650 screen brightness
Try Pressing the Option button and then P to bring up the Adjust Brightness control enabling you to dim or brighten the screen.
Dec 29, 2007 | Palm Treo 650 Handheld
Screen goes dim under different user
could be an issue of his resolution and refresh rate settings are close to being out of range for the monitor. Try lowering these settings to get better performance.
Oct 25, 2007 | HP Vs17 17" LCD Flat Panel Monitor
Monitor dims for one account, not the other
I would first contact the GF administrator and ask them if they've heard of this before. Then I would contact Acer.
Jan 18, 2007 | Acer AL1916B 19" LCD Monitor
Screen goes black
I recently had a similar problem with a MAG LCD monitor. Try the following to see if this resolves your problem: - set brightness to a lower level. On LCD monitors you can go as low as 0 and still see the screen. With my problem when I set the brightness below 70% the problem went away. A few days later I turned it all the way up to 100% and the problem did not return. However I did not continue to keep it at that level. I found no need for it and find 50% to be exceptable for my needs. I would say yes it does have something to do with the lamp controler which controls the lamp brightness. I do not know all the technical reasons why a controler starts to have this sort of problem. If your monitor is still under warranty I would take advantage of the free repair otherwise keep the brightness below the level that causes the problem; for me that was under 70 percent. I hope this solution works for you. Perhaps there are others that can give you all the technical reasons why a controler starts to exhibit this behavior. Sincerely, Dean Kenneth Robinson
Aug 14, 2006 | LG Flatron F700P 17" CRT Monitor
LG Flatron 295LM 22" LCD Monitor Logo
194 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
