Question about Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook
Updating... The error code is 80240016 It reads... Windows Updates is currently installing other updates... Its been a couple week. and it hasnt changed. I think its prevent me from ulodaing or downloading anything else..
    Genius:
  • 2,028 Answers
Sounds like the automatic updater has glitched. Start by trying a system restore from the system tools in the accessories section of the start menu. Go back to a point about a month or so back. However, since this is integrated into the operating system you may need to run a system repair with your recovery or operating system disc, if the restore doesn't clear up the problem.
Posted on Jul 29, 2008
I have two tablets that for some reason wont let me watch movies on them can you help me
Make sure that you have a good Internet connection and next try updating the Netflix app. They've been releasing updates every couple of weeks because of reported problems such as the issue that you're currently experiencing.
If that fails, totally remove the Netflix app and then re install it.
Jan 03, 2014 | Netflix
Cd drive code 39
What the Code 39 Error Is
CD-ROM/DVD Drive Cannot Start. (Code 39)
Code 39 is an error specific to the device manager. It is directly associated to drivers and errors that have occurred within them. Drivers are the small pieces of software that your hardware devices use to function. Each hardware device has it's own unique driver, developed by the hardware manufacturer, that contains the instructions allowing the hardware device to cooperate with other hardware devices and communicate with the operating system. Drivers are essential to the normal operation of any computer as they bridge the gap between hardware software.
Code 39 errors are amongst a wide array of device manager errors that all point to the same problem: the driver. It is not uncommon for drivers to become corrupted and produce errors during normal operation. Drivers are accessed constantly for every operation that a hardware device performs. Because of this, there are thousands of opportunities for errors during a single session of Windows. Because of this high rate of failure opportunity, many users have experienced Code 39 errors as well as many other device manager errors.
manually fixing Code 39 errors. Updating to the most current driver will replace the corrupted file with a new, better driver. Updating the driver will not only correct Code 39 errors but it will also introduce greater speed, performance, stability and compatibility. Driver updates are changes that the developer made to the original driver in the interest of all-round improvement. Driver updates often correct many other errors that are related to device incompatibitlity.To learn how to fix Code 39 errors manually, read this guide. The guide will provide steps for manually finding, downloading and installing the most current driver avaiable for your hardware devices. However, it is generally MUCH easier, safer and more reliable to use an automated tool. We've discussed using an automated tool to fix Code 39 errors below.
DriverUpdate.DriverUpdate is an easy-to-use tool that scans your unique hardware configuration for any device driver problems. Drivers that are out of date, missing, misconfigured or corrupt can easily be re-installed automatically by the program. The benefits of this program are endless. Most users not only have error messages fixed, but also will see a performance improvement since all of their system drivers can be updated! ( click here to download DriverUpdate ) RECOMMENDED
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Sony VAIO Laptop does not shut down with message "Please do not unplug updaing 11 of 55"
that message is from the automatic updates windows makes from time to time ...and this message usually appears after a fresh install with the operation system out of date ..and if you have the automatic updates ticked for to be made automatically ..The thing to be done is either let it install the updates...and it will shut down by itself...or ..start windows..and go to control panel ..and on the automatic updates...stop the updating process..This will cause a message to appear in the tray system every time ..to warn you that your computer is out of date ..and so ...but it has no real distress cause it will run like a charm even without the updates...(probably even faster ..cause if your computer is a little limited in resources the updates will slow it down a little ..
So ..this message is not a pest ..but the windows updating your operation system ..the only issue is when it is in error and takes more than the time it should ...usually it should not take more than a couple of hours for all 55 updates to be installed ...and this in case you have a slow computer...
Nov 04, 2011 | Sony VAIO Notebook
Dvd cd rom [ code 10 ] does not work
The Code 10 error code is generated when Device Manager has insufficient information or the error that is bubbled up by the device drivers is not recognized by Device Manager. Additionally, this error may occur when one of the drivers that the device needs does not start. If many drivers are being used by a particular device, it can be difficult to determine the one that failed.
The Code 10 error resembles the following: This device cannot start. (Code 10) The most common resolution is to update the drivers that are associated with the failing device. To do this, follow these steps:
  1. In the device's Properties dialog box, click the Driver tab.
  2. Click Update Driver to start the Hardware Update Wizard.
  3. Follow the instructions to update the driver.
Note You may be prompted to provide the path of the driver. Windows may have the driver built-in, or the driver files may still be installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site. uparrow.gifBack to the top Typical Code 10 error issuesThe Code 10 error pertains mainly to hardware and device driver issues or to compatibility issues between hardware drivers and additional software that is installed in Windows. Therefore, we recommend that you troubleshoot these issues by focusing on device drivers, on device configuration issues, and on hardware compatibility issues. Incompatible, outdated, or corrupted device drivers If you suspect that the Code 10 error is related to incompatible, outdated, or corrupted device drivers, try the following troubleshooting methods. Method 1 Update the hardware's device driver through Windows Update. To access Windows Update, visit the following Microsoft Web site: http://update.microsoft.com Method 2 Update the device drivers from the vendor's Web site. Follow their installation or update instructions.
  • If the device was preinstalled on the computer, visit the computer manufacturer's Web site.
  • If the device was installed after the purchase of the computer, visit the device manufacturer's Web site.
  • If the device was preinstalled on the computer, and the computer manufacturer does not have an updated driver for the device, visit the device manufacturer's Web site.
Note Make sure that the device drivers that are being installed are compatible with your current Windows version and platform.
Note In reviewing customer feedback, many of the Code 10 error issues are related to devices connected by using a USB port. As mentioned earlier, make sure that you have the most current drivers installed for the device together with any updates for Windows. In the specific case of Windows XP, review the following article to determine whether it applies to your situation: 925196 A computer that is running Windows XP cannot detect a USB flash drive, an Apple iPod, or an external hard disk drive
If you are running Windows XP and cannot install Windows XP Service Pack 3, review the following article to determine whether it applies to your situation: 940514 USB devices do not work after you disconnect and then reconnect a USB hub from a computer that is running Windows XP Device configuration issuesIf you suspect that the Code 10 error is related to missing software updates and service packs, try the following troubleshooting methods:
  • Install the latest Windows service pack.
  • Use Windows Update to install the latest updates for Windows. To do this, visit the following Microsoft Web site: http://update.microsoft.com
  • Install the updates that are specific to the computer or to the device. To do this, we recommend that you visit the computer manufacturer's Web site or the device manufacturer's Web site.
Software and operating system updatesIf you suspect that the Code 10 error is related to missing software updates and service packs, try the following troubleshooting methods:
  • Use Windows Update to install the latest updates for Windows. To do this, visit the following Microsoft Web site: http://update.microsoft.com For more information about how to obtain the latest Windows service pack, click the following article numbers to view the articles in the Microsoft Knowledge Base: 322389 How to obtain the latest Windows XP service pack 935791 How to obtain the latest Windows Vista service pack 889100 How to obtain the latest service pack for Windows Server 2003 968849 How to obtain the latest service pack for Windows Server 2008
Jun 12, 2011 | Dell Computers & Internet
VGN-N230N can not read SD card when install windows 7. (vista is ok)
Download all the windows 7 updates and install then restart. Windows update are not only updating your windows 7 but also updating your hardware driver. After updating try again your sd card or if still the same can not read try some memory card reader then test it to your laptop. Have a nice day.
Mar 26, 2011 | Sony VAIO VGN-N230N/B PC Notebook
Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Jun 29, 2010 | Computers & Internet
How can i fix this error code? error code :
Is this for a Realtek audio driver? Try this: Here is the solution:
  • Open Device Manager (Start> Control Panel> System> Hardware)
  • In the "View" menu , select "Devices by connection":
  • Disable and uninstall by right clicking on "Bus Driver for Microsoft UAA High Definition Audio":
  • You can now install the drivers normally and without error.
If you still have problems, uninstall and delete the audio driver file and get a new driver file, it could be corrupt, or even the wrong one. A great program for locating current driver files is Drivermax...I love that program. You can download 2 drivers a day for free with it.
Jun 14, 2010 | Foxconn 945GZ7MC-RS2H Motherboard
HTTP 400 BAD REQUEST
First, try updating windows. (Read everything below).
There is an error in windows .Net framework 1.1. Microsoft has a fix for this. You can read about it & manually repair this error at MS site. Click on the link below;
http://support.microsoft.com/kb/826437
What you want to do when updating windows!
Do not use Express. You want to install all .Net framework updates (one at a time). Re-start your system when windows tell you too. There are updates up to .Net framework 3.5 with (SP3) & this will take some time.
Cheers!
Run into a problem, post it here.
Mike
May 03, 2009 | Computers & Internet
Windows update error 80240016
Could you download and run the program Dial-a-fix from http://www.softpedia.com/get/System/System-Miscellaneous/Dial-a-fix.shtml
I have tried this with many computers and it worked all the time.
Jun 17, 2008 | Microsoft Windows Vista Ultimate Edition
Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook Logo
52 people viewed this question
Alun Cox
