I want to download and install yahoo messenger 11 but it said yahoo messenger is not working correctly and notice appears download application failed. What is the best steps to do in this problem?
The error clearly says that the application is having problem so it couldn't be opened or run. Your only option to repair the Yahoo! Messenger or to re-install it (both a more or less similar). First of all, download the yahoo messenger and then install it, once everything is done correctly, it should work properly.
Please follow this LINK for the instructions on how to download and install it. Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Check you completely removed yahoo messenger or not?restart you computer and download another file of yahoo messenger beta 11 because previous file may be corrupted.
I would advice uninstalling 11 beta and just installing version 10: http://messenger.yahoo.com/download/
It should work just fine on Vista 64-bit. (32-bit applications are reverse compatible.)
Good luck.
Perhaps you can do uninstall first and try to restart your pc/notebook. Try to install it again and perhaps you could try the offline installer from here :http://download.yimg.com/ycs/msg/dl/msgr10/us/ymsgr1000_525_us.exe
Perhaps you could give us what problem that occurs (the warning, alert etc)
Sometimes proxy setting or a firewall or even the antivirus can stop Yahoo Messenger from downloading and installing properly. If you've turned off the firewall, you may want to have a look into your proxy settings or the antivirus.
Alternatively, you can download the application from a different website like Softpedia. Yahoo will only give you an installer which will download the application and cause one of the above problems. Here's a link to Yahoo Messenger 10.
Sometimes proxy setting or a firewall or even the antivirus can stop Yahoo Messenger from downloading. If you've turned off the firewall, you may want to have a look into your proxy settings or antivirus.
Alternatively, you can download the application from a different website like Softpedia. Yahoo will only give you an installer which will download the application and cause one of the above problems. Here's a link to Yahoo Messenger 10. If you're addamant to get Yahoo Messenger 8, here is the link to it, but notice that the current version is 10.
first remove the program from control panel/add remove programs. then download and install this free utility >> http://www.ccleaner.com/ run cleaner and registry. after you're done, reinstall Yahoo Messenger. hope this helps.
